#41 |
How many of these have you seen?
1928 Roadster (CA67) 1931 Deluxe Coupe RHD 1931 Victoria RHD Model A's don't leak oil they just mark their territory. |
#42 |
![]() Nice "jewelry!! #1, 3, 4, & 5, are pictures of items I either have in my shop now, --or just sent out. Not sure what I am missing on image #2. Are #6 & 7 export items? |
#43 |
No timing pin hole????
Adjust your points with gentle blows of a 2 pound hammer ![]() |
#44 |
what lens is in the fender light?? i have a 28/9 cowl light with a mini 28 fluted lens thanks
#46 |
The instruction sheet was in the envelope that hung from choke knob. These were the first instructions offered for the "New Ford" by Ford Canada.
#47 |
maybe picture 2 goes with 3 ?, timing pin directly into a dimple on flywheel?
1931 Slant Windshield fordor |
#48 | |
![]() Quote:
#49 |
Yes, that is true but if I recall correctly, it does not show a print, --or more to the point, an assembly drawing print or even a print for that specific bushing. It has been awhile since I looked at that page in the S/B but I think it actually lists the bushing number. What I was curious about, was if there is an M-Spec listed for that bushing on the print(s) to see exactly what the composition was. Again, I have not thought about this in awhile but I am thinking Ford was beginning to use greaseless bushings in quite a few areas of the car (brake distributors, etc.) and I was just curious as to knowing if the bushing material was the same.
#50 | |
![]() Quote:
#51 |
It is kind of hard to find an original Ford Bakelite 'Mushroom' gear shift knob for the early '28 Model A. I had one on my Dec.'27 Tudor, and I still have one now in my collection of unique 'A' stuff.
#52 |
A set of K-D Model No. 22 Side lamps. They screw to the door post on 28/29 closed cars around the center door hinge. Has the vertical lens similar to the fluted 28. Would be better than fender lights because with those, your wife can't sit on the fender.
![]() Also, Simpson's Snappers. Installed on the rim and if the tire gets low, they will snap while driving. I have a set that says they were made for the "new Ford". They were made here in Wichita and even going to the historical museum I can't find any information on the company. Must have been a "fly by night" outfit. |
#53 |
I don't understand this flywheel housing...
It's set-up for the VE style timing, but uses the 3rd style housing? Also,...it uses the 2nd style inspection shield.. What gives? |
#54 |
Never have even seen a picture of one like it before ??.. A little re-work ??..
#55 |
This was the flywheel housing that was fitted to *CA67*
#56 |
Steve Plucker, I also have an original Lap Robe in my 30 Town Sedan. Now you know of two of these.
#57 |
Early rubber fender step pad has Ford script in the center square, and light switch with instructions. Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical. |
#58 |
An original unmodified ABELL starter, and an NOS FORD script ABELL pinion.
#59 |
in post 16, there is a Picture from early Top.. Note the Boss , for Lock pin to the Distributor.
https://www.fordbarn.com/forum/showthread.php?t=52070 |
#60 | |
![]() Quote:
