Old 06-01-2012, 06:08 AM   #21
oldford2
oldford2's Avatar
Default Re: Anti chatter rods 1947 sedan
"Chatter" can be caused by a combination of factors:
Loose or worn front motor mounts
old, oil soaked transmission mount
worn out rear spring shackles
loose u-bolts on rear spring
Also, driver clutch engagement technique can worsen the chatter. When we first got our 46 it chattered for me and not much when my wife drove. Then noticed she was "slipping" the clutch on start up. So, the bottom line is fix all of the above, try different clutch engagement techniques and if you have rods, use them.
John
oldford2 is offline   Reply With Quote
Old 06-01-2012, 06:48 AM   #22
41ford1
41ford1's Avatar
The link is a detail on building the aftermarket anti chatter device.
http://www.flatheadv8.org/chatter.htm This page is in their techno section.
If you haven't checked out that forum there is a lot of good info there too.
41ford1 is offline   Reply With Quote
