Old 12-17-2019, 08:06 AM   #21
mike657894
mike657894's Avatar
Default Re: Head Bolt Torque-Hot or Cold?
torque numbers are always cold. because the first time or in factory. the engine is off so its cold.
mike657894 is offline   Reply With Quote
Old 02-26-2020, 12:08 PM   #22
father-son
Very helpful thread here. We are newbies with 200 miles on a new motor. We were re-torquing (60 lbs?) the high compression head after a several miles so the engine was hot. Once we read this thread & re-torqued at increments of 10 lbs each when motor was warm the head bolts went from 35 lbs to 60 lbs. As a precaution we'll drain & replace the engine oil.
father-son is offline   Reply With Quote
