Old 05-22-2011, 10:12 AM   #21
bobpo
bobpo's Avatar
Default Re: Morning Coffee Safety Lesson
Well Brian, you caught me on that one, about 27 too much. Thanks. I guess I was just over-excited after seeing this kind of thing again. Been gone 19 years......
bobpo is offline   Reply With Quote
Old 05-22-2011, 10:56 AM   #22
tdlmomowers
tdlmomowers's Avatar
Apparently what is going on, With the pitch of the driveway, he could not check his oil level with any accuracy, so he raised the rear of the car to make it sit level so he could get an accurate reading.
tdlmomowers is offline   Reply With Quote
Old 05-23-2011, 01:51 AM   #23
dumb person
dumb person's Avatar
They probably lack lots of tools (i have done worse when desperate)
dumb person is offline   Reply With Quote
Old 05-23-2011, 10:37 AM   #24
james hitchcock
james hitchcock's Avatar
But checking the transmission fluid it says to be on a level surface.
james hitchcock is offline   Reply With Quote
Old 05-23-2011, 12:10 PM   #25
kp
kp's Avatar
Reminds me of the time I was sent on an investigation(30 years, Full time Fire dept Rescue Squad)guy had drove his Taxi up on the curb to raise it enough in order to get under and replace the u joint,vehicle had been setting there good while with no activity goin on.Guy had got under and removed the drive shaft(no Chock blocks) car rolled off the curb and came down on him.Needless to say DOA .
kp is offline   Reply With Quote
Old 05-23-2011, 12:17 PM   #26
Bruce Lancaster
Poor devil's last thought was probably "Huh? It's in park, it can't do that!"
Dim and flawed understanding of things like mechanics and gravity can get serious...
But the case above is EASY...just tilt the camera a tad and reshoot! Problem solved!
Bruce Lancaster is offline   Reply With Quote
Old 05-23-2011, 12:58 PM   #27
Larry Seemann
John Wayne said, "Life it tough --- It's even tougher if you're stupid."
Larry Seemann
Larry Seemann is offline   Reply With Quote
Old 05-23-2011, 01:44 PM   #28
JoeWay
JoeWay's Avatar
Austin Lounge Lizards
lyrics–Mark Graham
Listen Here
Life is hard, but life is hardest when you’re dumb
No joie de vivre, just endless hours of tedium
With a negative IQ you’ll be lonesome sad and blue
You wait for years, but inspiration never comes
Thoughts you don’t have remain unheard because you cannot find the words
Between your ears a dark and silent vacuum
If there’s a void behind your face
why not rent out the vacant space
Why not just lay back and smoke a bowl of opium
If being stupid is your fate just relax ’cause it’s too late
1929 Tudor
since 1962
Feather River A's
JoeWay is offline   Reply With Quote
