11-09-2022, 08:37 PM | #21 | |
Re: Heat; Where's it coming from?
11-10-2022, 12:02 PM | #22 |
My A came with a homemade firewall insulator that works pretty good but even after I installed a new felt pad around the column and pedals you can still see daylight through it. This pad came from Snyders, does anyone else make or carry a thicker pad?
11-11-2022, 12:29 PM | #23 | |
Regards Bill |
11-12-2022, 11:02 PM | #24 |
Hello, non original firewall insulator are available from vendors, they are a hard molded plastic with fiberglass on the inner side . Ford didn’t start using them until 1932 .Maybe someone who has installed one can say if it helps.
11-15-2022, 09:46 AM | #25 |
I had the same problem, my wife could feel the heat radiating from the muffler through the floor.I removed the floorboards and painted them with a product called HNR (heat and noise reducer) I purchased from Scorpion Coatings Company, they sell bed liner coatings as well. HNR is a latex based coating, easily applied with a brushed made a big difference in the heat radiated through the floor.
