01-22-2017, 07:59 PM | #21 |
Re: Not Model A, but I thought you guys would get a kick out of this.
Many years ago when I was young I had a 1935 Ford with a bad fuel pump that worked on and off, and no money to squander on another fuel pump I drilled a hole in the gas cap, installed an inner tube metal valve cut from an old era inner tube and I was all set. When the fuel pump failed I used my tire pump, about 4 pumps of the hand tire pump was good for about 5-6 miles. My longest trip was about 250 miles and 2 chums in the rumble seat manned the tire pump when the engine began to sputter and we just kept driving without a pause. When I replaced the full pump I kept the gas cap with inner tube valve through it just for emergency as long as I owned the car.
01-22-2017, 08:25 PM | #22 |
barnstuf: that is a cool story. Jeff
Let's let pylons, be pylons! |
01-22-2017, 08:36 PM | #23 |
If you squeeze the can to you get fuel injection?
01-22-2017, 09:08 PM | #24 |
This has turned into an interesting thread.
01-24-2017, 06:53 PM | #25 |
These two posts are great! I am going to copy them to my Model A folder. I hope that's OK.
Gold Digger Wasn't fuel pump trouble but had carb trouble once on an old 57 ford. I took the carb off and beat the end of the gas line almost together and wired the line where it sprayed a small amount of fuel down the intake. didn't run worth a dime but made it about 3 1/2 miles to home. barnstuf Many years ago when I was young I had a 1935 Ford with a bad fuel pump that worked on and off, and no money to squander on another fuel pump I drilled a hole in the gas cap, installed an inner tube metal valve cut from an old era inner tube and I was all set. When the fuel pump failed I used my tire pump, about 4 pumps of the hand tire pump was good for about 5-6 miles. My longest trip was about 250 miles and 2 chums in the rumble seat manned the tire pump when the engine began to sputter and we just kept driving without a pause. When I replaced the full pump I kept the gas cap with inner tube valve through it just for emergency as long as I owned the car. |
01-25-2017, 07:50 AM | #26 |
1928 "A" Phaeton (mid year with many early features) 1933 "V8" Closed-Cab Pickup Truck (originally a Model B, 4 Cylinder dating to May, 1933)
01-25-2017, 08:04 AM | #27 |
Got to love Bugs. I had a bunch back in the day. Once the throttle cable broke at the pedal. I pull it out through the dog house and ran it along side the car. It was a manual hand throttle, but it got me home.
01-25-2017, 10:41 AM | #28 |
I had quite a few old VW's too.My first car was the A,but it was really too cold to drive a lot in the winter.I bought a 59 VW,it had no heat but it was a lot warmer than the A.I broke the throttle cable on that one night,so I sat on the bumper and ran the throttle while my friend shifted and steered it.The intention was to just get out of the downtown Christmas traffic and find a place to park it,but we were doing so good we decided to make the 7 mile trip home.That was one cold ride home with one hand around the hood hinge holding me on,and the other one trying to regulate the throttle .
01-25-2017, 11:14 AM | #29 |
Great story - "Yankee Enginuity" never owned a VW aircooled but would not mind - cool cars I think.
Steve 1930 Model A Roadster |
01-25-2017, 11:45 AM | #30 |
One winter night, many year ago, I was driving a Trackmaster up a mountain road on Baffin Island and the return spring on the throttle linkage broke. What to do? I had about 8 or 10 miles to go. I tied the gas pedal to my boot so I could pull the gas pedal back up. Of course in the mountains the 2 way radio wouldn't work so I couldn't report in. The road was covered w/snow drifts, so every 50 or 100 yards I had to accelerate to climb over a drift and then back off the throttle to go down the other side. Easy enough when the spring is there but not so easy w/a manual return. Finally got to the base I was going to and got raked over the coals for being so late.
01-25-2017, 11:54 AM | #31 |
If our friends of the law would notice this construction on the raod over here they would stop you immediatly and forbid you to continue your trip !
( and for me the empty unmolested oil can is worth more the a VW fuel pump) |
01-25-2017, 10:10 PM | #32 |
Luv it!
1931 Std Roadster 1946 Chevy Truck 1956 BelAir Convertible |
01-26-2017, 02:53 AM | #33 |
The Australian outback is notoriously hard on cars. The indigenous people that live there are notorious for the same thing, but also for their ability to keep heaps of sh** mobile. A while back there was a great TV series called Bush Mechanic, which took the pi** out of this situation. There are a few clips on YouTube with some classic roadside fixes. It was made BY black fellas ABOUT black fellas, which makes it still P.C., right? Enjoy.
https://youtu.be/AmmDsv-CPdA |
01-26-2017, 05:55 AM | #34 | |
Reminded me of what happened when car,bus or boat broke down 1968 in Vietnam. Those guys were as good as Macgyver ... Fixing with whatever was available !! |
