02-05-2016, 01:49 PM | #21 | |
Re: need ideas to lift model a on 2 post lift
I guess you are sheltered Here is my special order Denali diesel getting prepped for delivery this year at the dealer.... Needless to say I ordered another one |
02-05-2016, 06:45 PM | #22 |
this is what I was thinkin about ,,thanks Mitch..
02-05-2016, 07:23 PM | #23 |
Made these up, works well
02-05-2016, 08:34 PM | #24 |
We will need to start a Forum patents office with all these great innovations.
02-05-2016, 11:42 PM | #25 |
Phred,
Gooooood idea, think I'll make one. |
02-06-2016, 12:17 AM | #26 |
02-06-2016, 08:42 AM | #27 |
02-06-2016, 11:07 AM | #28 | |
02-06-2016, 11:27 AM | #29 |
a truly clever idea.
Looks like the thru bolts in the lift arm eyes are at least 1" diam
'31 180A |
02-06-2016, 12:42 PM | #30 |
Does the rigid frame bolted to the swing arms allow for cars of different wheel bases? I'm trying to picture how you could swing the frame forwards and still have the lift arms adjustable. Definitely going to make one....
Frank |
02-06-2016, 05:22 PM | #31 |
If buying a new lift,concur about the 4 post variety. The post base mounting load requirements are spread over 4 corners rather than 2 as stated by others. In earthquake country, there are 2 schools of thought for the 4 poster: one, to bolt to a solid foundation, the 2nd, to leave the lift unbolted to allow the base plates to slide when lateral forces are at play. The latter seems counter intuitive, but an engineer should probably be consulted in any event for proper mounting.
02-06-2016, 07:27 PM | #32 |
thought I sent this ,,butt here is what I was lookin for..good idea..)..
02-06-2016, 08:21 PM | #33 |
Yes, just pull or push the crossbars since the arms slide as well as swivel.
02-13-2016, 06:53 AM | #34 |
mr phred posted a picture of adapters for the A...does any one have dimensions and size of material for this project..i wanna make me one..thank you for all inputs ,comments ,and ideas..Charles..)..
02-13-2016, 11:51 AM | #35 |
Phred, are those long cross pieces solid? Schedule 80? Or?
Tnx, Ken
02-13-2016, 12:41 PM | #36 |
Long rails and short interior cross bars are 2" OD, 3/16" wall, DOM.
Exterior cross bars are 1 1/2" x 3" rectangle tubing. 1 1/2" x 1 1/2" angle caps the ends at the bottom for addition strength. Each sections weighs about 75+ pounds. Probably some overkill designed in to it. |
02-13-2016, 08:52 PM | #37 |
thank you mr phred..)..
02-13-2016, 09:29 PM | #38 |
Has anyone figured out how to adapt a scissors lift for use on a Model A? I have had the Mohawk lift in the photo for about ten years, but it's pads are designed contact the frames of modern cars, which are on the outside as opposed to the Model A, which have narrow inboard frames (as you all know). The pads do not line up with the narrow Model A frame.
Thanks |
02-14-2016, 12:12 PM | #39 |
thanks phred
02-15-2016, 05:33 PM | #40 |
A few people have asked
for a bit more detail regarding post #36
Attached are some photos |
