07-25-2015, 10:08 AM | #21 |
Re: Starter motor removal question
I was just sayin', not implying anything.
07-25-2015, 10:18 AM | #22 | |
When I would bring her back into the garage, I retard the spark before shutting her off. Again, I would notice virtually no difference in the sound of the engine when the spark is retadred. It appears the lever is moving the rod that goes to the distributor, however it now makes me wonder if the spark is being retarded enough. How can I tell? |
07-25-2015, 11:46 AM | #23 |
make sure you get full throw in each direction at the distributor where the rod hooks up..
then reset your points and timing to specs |
07-25-2015, 12:20 PM | #24 |
To amplify what MikeK was telling you, here's a photo of how it should appear.
You will notice your starter drive is partially engaging the helix due to the sprung spring which gave you such a hard time in removing the starter.
I Love Anything That Turns Money Into Noise |
07-25-2015, 01:42 PM | #25 |
I hope NO ONE ridiculed Smittykid, cuz he didn't know how to take off his starter!!! REMEMBER, he might be the expurt that does your INCOME TAXES or replaces your burned out HEART VALVE! Like the Dr. that replaced Greggs' heart valve & discovered a HUGE ANEURYSM on his main AEORTA & repaired it with plastic tubing & clamps!
Bill W.
07-25-2015, 03:44 PM | #26 |
Also with the bendix removed from the starter shaft, rotate the starter motor, and see if the shaft is bent. Bob |
07-25-2015, 05:13 PM | #27 |
Bill Ever since I enrolled in model A 101, you have been a light at the end of the tunnel, ofconfusion and not knowing my ass from a cut out! I look forward to your humor every day. Keep it up and pet the dog for me. Don in North West Indiana. 20 miles from Dillengers Jail at Crown Point In. Get your self to my house and I will take you on trip to the Jail !
07-25-2015, 06:27 PM | #28 |
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
07-25-2015, 10:24 PM | #29 |
Connect jumper cables to it and see if the starter spins. The bendix's only function is to engage and disengage the flywheel. replace the spring on the bendix if the starter works before reinstalling it. Make sure you get the correct spring for the bolt size. The later bolts were larger I think 3/8"
07-26-2015, 12:06 PM | #30 |
Be sure to use new locking tab washers with the new spring (or new Bendix) and be sure to use the long spring bolt in the end of the shaft, as it must engage a pocket in the shaft. Be sure the tiny pin and spring on the pinion weight is free and has a drop of oil on it.
The helix must be free of rust and dirt. I give it a light coat of thin oil, such as ATF. It will keep it from rusting during winter or humid storage. |
07-26-2015, 01:15 PM | #31 |
I might add one more thing to check, a good ground on the ground strap to the frame. I have lost complete starter function due to a bad ground.
07-28-2015, 09:24 PM | #32 |
Just a minor update. I ordered a new bendix drive from Snyder's. I contacted my local starter rebuilder guy. Hopefully I'll be able to install the repaired starter by the first of next week. I'll get her timed and the points set and see what happens. Thanks again for all your help.
07-28-2015, 09:44 PM | #33 | |
Bob |
08-02-2015, 08:23 PM | #34 |
Retard the spark when starting.
08-07-2015, 03:40 PM | #35 |
Another update. I received the new starter drive from Snyder's & had the starter guys remove the old one & install the new one. Got it home & reinstalled the starter. It turned the engine over about 4 different times then froze up. I took it out & back to the starter guys. The gear was hanging up. I purchased a new (made in USA) starter drive & the installed it for me. Took it home & reinstalled the starter. This one works like a champ! Snyder's have been super about the refund. They will even refund me my return postage.
Reset the points and followed Les Andrews' instructions on timing. She fired right up and I took her for about a 2 mile ride. Ran smooth, but no power. Also, when i got back to the garage the engine compartment seemed hotter than usual. Narrowed the point gap to about .019. Now i can't get it started at all. Tried to set the timing again, but I'm having an awful time locating the detent in the timing gear. What did I do wrong? |
08-07-2015, 04:26 PM | #36 |
Your timing is most likely late and that will cause excess heat and loss of power. Crank the engine slowly and push a small Philips screwdriver into the timing pin hole to feel for the detent.
08-07-2015, 04:32 PM | #37 |
Loosen the dist cam screw, turn the dist cam CCW a smidge & see if it sounds better. ONCE you learn the "proper" sound of a Model A, you can set the timing by EAR!
PROPER SOUNDS ARE: 1 Spark up= a smooth, rhythmical, TADA-TADA-TADA-TADA. 2 Spark 1/2 down = a faster, smooth idle. 3 Spark full down = an even faster, but "rolling" idle. Bill W. (With ALL THE TIME SOME SPEND, JUST SETTIN' THEIR TIMING, I could probably have Vermin FINISHED!) SA Bill W.
08-07-2015, 08:23 PM | #38 | |
08-08-2015, 11:50 AM | #39 |
If NEW to Model A's, just remember, sorta' match advance to road speed! DON'T just "SET IT & FORGET IT"! Too bad the advance lever is not marked, 10 MPH, 20 MPH, 30 MPH, 40 MPH & "BALLS' OUT"!! When "rookies" watch you doin' this, they think you're a FRIGGIN' GENIUS!
Some feel that FULL ADVANCE gives MORE power on hills, WRONG!!--Again, match the ADVANCE to your ROAD speed! Using the advance lever correctly even gives you BETTER gas mileage. Cars with centrifugal advance, do it for you, AUTOMATICALLY! Hope I said all this right, I just BARELY had an ANTI-PAIN PILL & COWBOY COFFEE. Bill W.
