07-01-2015, 12:52 PM | #21 | |
Re: Coil
Model A coils face/point down. Thats how they were made. These coils were resin filled. |
07-01-2015, 01:00 PM | #22 |
Re: Coil
The only way I would think is to take a coil, drill a hole to drain the oil --to know the volume and then cut the bottom of the coil off.. then put the oil back in and see if the oil covers all of the windings... if so, I would think upside down would be fine..
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
07-01-2015, 04:16 PM | #23 |
Re: Coil
I live 50 miles out of town and always point my coil tower up. Learned this in the 50's. they get hot and misfire or stop. Let them cool and turn them so that they are pointing up and you should be able to drive to the part store.
Dan |
07-02-2015, 10:52 AM | #24 | |
Re: Coil
07-02-2015, 11:06 AM | #25 | |
Re: Coil
Just kidding
07-02-2015, 12:37 PM | #26 |
Re: Coil
07-02-2015, 01:49 PM | #27 |
Re: Coil
Upside down should be fine unless the seal starts to leak oil. When the coil heats up the pressure tries to escape and pushing the oil out is the only possible escape. It the coil is right side up, then the oil is away from the seal.
