07-06-2013, 08:32 PM | #21 |
Re: Re torquing head gasket--hot or cold?
If you use a head gasket with silicone the answer is stone cold per mfg. instruction for reasons previously stated.
07-06-2013, 09:41 PM | #22 |
07-07-2013, 12:08 AM | #23 |
I torque mine COLD & I DON'T loosen each nut.
Bill W.
07-07-2013, 06:41 AM | #24 |
Yep.
07-07-2013, 06:47 AM | #25 | |
07-07-2013, 08:30 AM | #26 |
07-07-2013, 08:36 AM | #27 |
i changed my silicone head gasket out the first week never again.
i rate them with the modern lower dist plate garbage Last edited by Mitch//pa; 07-07-2013 at 08:59 AM. |
07-07-2013, 09:22 AM | #28 |
The modern silicone gaskets are like oil type or torquing the head nuts, everyone has their own opinion and uses what works for them. I don't like them and have had some bad experiences using them so, I use copper. Use what you like and what works for you. Just understand, you may have to spend some money to figure it out.
07-07-2013, 01:38 PM | #29 |
i think most like the copper style head gasket rather than the new style silicone one because thats what they were used too. old timers old timer thoughts. the new silicone style gaskets were also not available in 1930 ish. so for a period car resto a copper gasket should be used.. i myself will run a silicone gasket since they do help with small imperfections in the head or block surface. i like old time things with a dash of modern progress
07-07-2013, 04:01 PM | #30 | |
07-07-2013, 04:01 PM | #31 |
Your indications about the silicone impregnated head gasket being problematic are worrying me.
When I bought my Snyder 5.5 head last year, they suggested I use the pricey silicone impregnated gasket, and I did as advised. I've got a couple of thousand miles on the engine so far without any problems or evidence of "weeping", and I have re-torqued the head 3 times. Am I beyond the known problems and infant mortality issues, or should I assume the head gasket will soon fail? Thanks in advance. |
07-07-2013, 06:26 PM | #32 |
As I said a lot of folks with "runners" ( slang for modifed model A) , use the silicone impregnated gasket and have no problems
