09-05-2023, 04:17 PM | #21 |
Re: 8BA engine
Before you do anything, buy, borrow, or steal a known good stock head and check your clearances, over both the valves and the piston crown. You have to know what you are starting with.
Knowledge is power. |
09-05-2023, 05:55 PM | #22 |
Re: 8BA engine
And kids playdough, or grandkids or in my case great grand kids can be used to find clearance issues.
09-06-2023, 08:29 AM | #23 |
Re: 8BA engine
I used a dial indicator and found my valves are lifting .385". I took digital calipers and a micrometer, and as near as I can tell I have .319" to .350" valve clearance in the head. When I consider a gasket compressed to .050", I would need at least .030 more clearance in the head. .319" clearance plus .050" gasket = .369" space available, and .385 required. Can I safely take that much out of the valve port on the head. I have also found a company the makes thicker gaskets.
09-06-2023, 09:05 AM | #24 |
Re: 8BA engine
I think you need another set of heads. It sounds like the ones you have have been milled to the excess, in addition to whatever else they have been through. . I seem to remember you saying that you have "8BA" heads. A good set should be easy to find.
Getting the proper clearance over the piston head is one of the most rewarding things you can do with a flathead, in terms of both performance and personal satisfaction. Making sure you have adequate clearance over the valves is just another part of the process. I wouldn't put a flathead together without custom fitting the heads. |
09-06-2023, 11:26 AM | #25 |
Re: 8BA engine
It does seem like different heads are the right place to start.
thanks for all al |
09-06-2023, 02:27 PM | #26 |
Re: 8BA engine
Once you price them out, a set of good used heads will start to look pretty good. |
09-06-2023, 03:51 PM | #27 |
Re: 8BA engine
Where do you live ?
09-06-2023, 06:23 PM | #28 | |
Re: 8BA engine
The 8CM heads I have on the shelf measure .385"-.410" valve clearance. With a gasket that'll be over .450". Sounds like your heads have been milled quite a bit.
09-07-2023, 05:26 PM | #29 |
Re: 8BA engine
I don't know if 8BA heads are the same as 8CM heads, but if they are my heads must have been milled about .050". I will begin to look for different heads.
