05-14-2010, 04:25 PM | #1 |
32 Ford frame extensions
City:
Somerville
State:
Ohio
Search for one of four frame extensions for my 32 frame. There are two on each side behind the k-member to the rear and I miss one on the driver side. Also search for the middle piece of a 32 rear crossmember, because mine is cut to mount a 40th Ford rear. Unfortunately it is cut on the front side and so the wheelbase is a little shorter. I want to weld it back like original, because mine is missed. Search what you have, please. I've pictures included to show you what I mean.
Thanks, Alex |
05-15-2010, 01:48 PM | #2 |
Re: 32 Ford frame extensions
bump to the top
05-16-2010, 07:56 AM | #3 |
I have one for you. check your pm's.
05-16-2010, 04:58 PM | #4 |
