Thread Tools Search this Thread Display Modes
Old 07-20-2012, 10:40 PM   #1
Nostalgic1930
Default Anyone have a reds header for the stock carb setup mounted on their car?
looking to see who else has one on their car/ truck, i know there isn't to much performance , just looking for a picture all mounted up. im running into issues with the throttle linkage as well as the choke rod. thanks - Brett
Nostalgic1930 is offline   Reply With Quote
Old 07-20-2012, 11:33 PM   #2
Logan
Logan's Avatar
Default Re: Anyone have a reds header for the stock carb setup mounted on their car?
I didn't think it was possible to use the headers with stock intake for this reason.
Cowtown A's
Logan is offline   Reply With Quote
Old 07-21-2012, 12:25 AM   #3
Milton
Milton's Avatar
I can understand part of the problem is the intake being shifted away from the engine by the header plate thickness. The throttle should work if the arm is bent out to allow the throttle rod to clear #4 exhaust but the choke could be a problem. This is the best I can do because my stock intake is on another engine. Hope it helps, and tomorrow I will try some measuring.
Milton is offline   Reply With Quote
Old 07-21-2012, 01:23 AM   #4
ken ct
ken ct's Avatar
looks good milton,are those 94's or 92's. Real hairy looking. ken ct.
ken ct is offline   Reply With Quote
Old 07-21-2012, 03:53 AM   #5
Mike V. Florida
Mike V. Florida's Avatar
Only one linkage to one carb?
Old 07-21-2012, 10:41 AM   #6
miss victoria
will not work not even close, i run a webber
miss victoria is offline   Reply With Quote
Old 07-21-2012, 11:53 AM   #7
Roadster62
Roadster62's Avatar
Why not buy one from someone locally? Bill drives his Model A Coupe as a daily driver with manifolds he makes. Bob http://www.waccustoms.com/
Don't let the Horse Fly spoil your Picnic. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like.
Roadster62 is online now   Reply With Quote
Old 07-21-2012, 11:58 AM   #8
d.j. moordigian
Mike,
The mechanical hook-up is on the head side of the carbs....look close.
d.j. moordigian is offline   Reply With Quote
Old 07-21-2012, 02:11 PM   #9
Milton
Milton's Avatar
E-bay/Ford 94s with the AA-1 bases and intake throat vents. It took three to get two that matched. I never realized that there were so many different models. With kits and a few parts they worked great. Oddly, the 'new and improved' stuff (neoprene needles etc.) gave me the most trouble.
Old 07-22-2012, 12:28 AM   #10
Milton
Milton's Avatar
After examining the situation, it isn't the choke or throttle linkage that is a problem, it is the #2 and #3 exhaust pipes. The pipes will prevent the stock A carb and manifold from bolting up to the header flange because of their radius.
Search this Thread:
Advanced Search
