Thread Tools Search this Thread Display Modes
Old 07-14-2012, 09:47 AM   #1
visionary
visionary's Avatar
Default 1926 low speed drum
Hey guys, i need to replace the low gear drum in the transmission as the bands were so worn the rivets had dug in and ripped it up pretty good.
I asked the guy that is redoing my motor if it can be turned and he said it was to far gone, so my question is are the low speed drums the same in my 26 as in other years? i'm looking for a good used one and i thought i heard that the 26 and27 years were larger?
Thanks
Scott
visionary is offline   Reply With Quote
Old 07-14-2012, 10:13 AM   #2
Doug Money
Doug Money's Avatar
Default Re: 1926 low speed drum
26 & 27 are the larger ones. pre 25 are the small ones.
Doug Money is offline   Reply With Quote
Old 07-14-2012, 12:22 PM   #3
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
I just took a quick look in the Snyders catalog , WOW $515 for a new one...
Better find a used one ? Drums cant be turned in a lathe they must be ground on a grinder . A turned drum will screw the linings right off the band with the lathe marks.
Dont ask how i know that one ???
I would try Rons Machine Shop in Ohio , they built my last transmission. 513-738-7353
If it Makes Spark, we do it !!!!
www.bubbashotrodshop.com
BUBBAS IGNITION is offline   Reply With Quote
Old 07-14-2012, 12:24 PM   #4
yachtsmanbill
yachtsmanbill's Avatar
The L & R are all the same. The brake drum is wider on the 26-27. Take some brake cleaner, a wire brush and a magnafying glass to inspect the webbing on the drum. If all that passes then take it to a shop for a REAL inspection with magnaflux or what ever else they use. These are all prone to web cracking, and BARELY visble!!! ws
" Warning; the following contains content that the anal retentive may find offensive - please skip on to the next posting!"
yachtsmanbill is offline   Reply With Quote
Old 07-14-2012, 11:51 PM   #5
visionary
visionary's Avatar
Thanks for the info, but i hink i'm confused on what i need. the drum that is bad is the rear most drum, sounds like i need the brake drum. sorry for the confusion.
Scott
Old 07-15-2012, 02:58 PM   #6
tmodelman
tmodelman's Avatar
Call Bob's Antique Auto, Loves Park IL
Got a nice new '25 narrow brake drum, re-furbished with good used shaft, for much less than the new drums..they do the refurb for the wide drums too....they may also have a good used one in stock, sometimes if you are lucky.
tmodelman is offline   Reply With Quote
Old 07-15-2012, 07:37 PM   #7
Kohnke Rebabbitting
Location: 515-546-4551, 60615,330th Ave.,Clare, Iowa, 50524
Mr. Bubbas Ignition, if you turn a drum on a lathe and do it wrong, you will problems . If you have done about 350 of them in the last 45 years, and done them right, you will have no problems. You can ask how I know that.
Kohnke Rebabbitting is offline   Reply With Quote
Old 07-15-2012, 09:40 PM   #8
Farmallcub49
Farmallcub49's Avatar
I have them in stock, used
Andy
'OSO HANDY RESTORATIONS
Specializing in Model T Fords
320-293-1953
Farmallcub49 is offline   Reply With Quote
Search this Thread:
Advanced Search
