#21 | |
![]() Quote:
I am working on rigging up a solenoid on one door that will unlock the inside handle as a precaution for if I ever get locked out by the inside handles. That will just have the wires tucked up inside the door and if I ever need it just fish the wires out and touch them on 12v. That’s still in the thinking and planing stage but it should work. I need to get the door locks in and the glass in yo see where I can locate the solenoid.
I am building a 1939 1 ton express Last edited by ActionYobbo; 05-20-2024 at 11:16 AM. |
#22 |
Here is todays progress. Putting the key lock hole in the door. I drilled the hole to 3/8” and used a 3/8 drive socket that closely matched the diameter on the passengers door, a 3/8 bolt some fender washers and a spacer. Socket on the inside and fender washers on the outside.
Turned out almost perfect
I am building a 1939 1 ton express |
#23 | |
![]() Quote:
