Old 05-15-2024, 07:26 PM   #1
dean333
dean333's Avatar
Send a message via Yahoo to dean333
Default 33 Fordor windshield removal
After disconnecting the hinges, does the windshield frame slide off to the driver’s or passenger side? I’m assuming it’s slides on a pin as does the top of the hood halves.
Tim Carlig
dean333 is offline   Reply With Quote
Old 05-15-2024, 07:56 PM   #2
Newc
Newc's Avatar
Default Re: 33 Fordoor windshield removal
Pull the pin in the crank out mechanism [little hinge] -remove complete windshield. There are corner screws in bottom section for glass removal. Hinge sections are welded to top of frame. Right?
Old 05-16-2024, 11:29 PM   #3
rich b
rich b's Avatar
Unhook the regulator either by removing the the two screws or driving out the pin. Take out the header panel and remove the two screws from each hinge then lift the bottom edge outward and the frame will come straight out.
I usually scribe around the edge where the frame tabs meet the hinges as guide for reinstalling the windshield frame. Saves some messing around getting adjusted.
Old 05-17-2024, 07:06 AM   #4
dean333
dean333's Avatar
I was hoping the process could be completed externally without messing with the headliner. The reason for doing this is it’s a deluxe where someone painted body color over the chrome.
Tim Carlig
Old 05-17-2024, 08:35 AM   #5
rich b
rich b's Avatar
Unless somebody changed up the interior; removing the header panel does not entail messing with the headliner.
Old 05-17-2024, 09:12 AM   #6
Terry,OH
Terry,OH's Avatar
If the hinges are removed and the hand crank opener is removed from the frame the windshield should come off. The inside of the frame is painted black and for the Deluxe the outside is chrome. New frames are reproduced.
If the outside of the frame is painted you can probably remove the paint without removing the windshield.
Old Yesterday, 01:25 AM   #7
CrazyBackyardBuilder
CrazyBackyardBuilder's Avatar
Great info, I am going to be putting a Windshield in my '33 very soon. I think it is about time.
CrazyBackyardBuilder is offline   Reply With Quote
Old Yesterday, 11:04 AM   #8
petehoovie
petehoovie's Avatar
