07-06-2022, 09:30 AM | #1 |
What gear are you in?
I've read that it is not good to "lug" the engine. So when cruising at 30mph, what gear are you usually in?
07-06-2022, 09:43 AM | #2 |
Re: What gear are you in?
Cruising at 30 mph I'm in high gear. The engine would be screaming at 30 mph in 2nd.
07-06-2022, 09:55 AM | #3 |
Ditto
07-06-2022, 10:08 AM | #4 |
The owner's manual recommended shifting to 3rd at 15mph under normal conditions, i.e., you're not at WOT trying to gain speed. Lugging in a Model A is not solely a function of speed. You have to be applying high torque as well. You can shift to 3rd as early as 12mph if you have a light touch on the throttle.
07-06-2022, 10:09 AM | #5 |
The way I look at it is, there is a correlation to the amount of throttle and the strain on the engine. If you are in third gear going uphill at 20 MPH with a significant amount of throttle you are lugging, not so good! If you are in third gear going down hill at 20 MPH with little or no throttle you are loafing, no problem!
1929 Town Sedan (Briggs) 155B, Mitchell Overdrive 1935 Model 48 Tudor |
07-06-2022, 10:13 AM | #6 |
07-06-2022, 10:43 AM | #7 |
3rd direct or 2nd overdrive depending on road conditions, like going up or down a steep grade.
That's my car. Right now I am in low gear as my knee hurts. Old age.
07-06-2022, 11:31 AM | #8 |
Depends on how many hooves you got.. pull 9% at 45 mph 3rd low..feather throttle and shift into high at 15 mph if You want too.. don’t lug, and don’t over rev
07-06-2022, 02:36 PM | #9 |
A lot depends on if you are driving a fenderless Hot Rod or basically stock Town Sedan.
07-06-2022, 06:18 PM | #10 |
07-06-2022, 07:03 PM | #11 |
Awww, it’s all model A, just hopped up a little.. makes it fun
07-06-2022, 07:15 PM | #12 |
07-07-2022, 06:52 AM | #13 |
Enjoy it.. drive it like there’s an egg between your foot and the accelerator.
07-07-2022, 09:37 AM | #14 |
Fear of the Model A's engine is a correlation between the noise it makes and its RPM at various road speeds. In fact, The Model A's engine is of the low speed high torque variety, and all out for a stock one is a tad below 3000 RPM.
Bob Bidonde |
07-07-2022, 11:45 AM | #15 |
There’s a big gap between 2nd and 3rd gearing, so driving here in traffic, in S. California, I shift into 3rd around 20 mph, with better acceleration to keep up with traffic.
07-07-2022, 01:32 PM | #16 |
Terry, do drive a stock model a in Southern California traffic without the protection of a convoy?
07-07-2022, 05:09 PM | #17 |
3000 rpm? No wonder you threw a rod out the side of your block.
The Master Cylinder Enjoying life at the beach in SoCal... Last edited by The Master Cylinder; 07-08-2022 at 08:33 AM. Reason: Linked to incorrect post, corrected. |
07-07-2022, 11:42 PM | #18 |
Not sure what you mean by 3,000 rpm, or throwing a rod…..must be an inside joke.
07-07-2022, 11:46 PM | #19 |
Yes I do regularly drive my Model A solo here near Huntington Beach, on all the major surface streets. I do have a Mitchell OD, so I also venture out on the freeways at times, and also drive at night locally.
07-08-2022, 08:08 AM | #20 |
I drove mine solo in Sacramento.. but only after doubling the power of the engine and running a Mitchell.. even then I was bulldozed off of lights and tailgated, can’t imagine running a stock engine.
Cast iron drums, woven shoes,teds floaters,16” wheels with modern radials helped the stop and go.. Last edited by jack backer; 07-08-2022 at 08:15 AM. |
Thread Tools | |
Display Modes | |
