09-03-2017, 07:42 AM | #1 |
33 hub cap install.
Question regarding installation of hub caps on 33 coupe. Any tricks to this do not want to go on easily. Although I did have wheels powder coated could be part of issue paint seems heavier that original.
Everyone have a good Labor Day. |
09-03-2017, 08:46 AM | #2 |
Re: 33 hub cap install.
They should go on easily, so it is likely excess paint is constricting the openings for the caps in the wheels. Powder coating usually leaves a much thicker paint film thickness than sprayed on paint. If you cut off some of the paint around the circumference of the opening with a box cutter with a new blade you should be able to install the caps readily.
09-03-2017, 11:41 AM | #3 |
Thread Tools | |
Display Modes | |
