12-29-2012, 02:47 PM | #1 |
Radiator / antifreeze question
Can someone tell me how many gallons of coolant the model A system holds?
Should I mix anti freeze 50:1 like any car? Please confirm there is "NO" thermostat - if there is one where? Thanks |
12-29-2012, 02:54 PM | #2 |
Re: Radiator / antifreeze question
Therre is no thermostat, but I install them on my A's. 2 1/2 gallons should work, and I always use 50/50 antifreeze. Any antifreeze and never had a foaming problem.
12-29-2012, 03:27 PM | #3 |
No thermostat was originally used in a Model A.
Cooling capacity 3 gallons......1 1/2 gallon of undiluted antifreeze (full strength) mixed with 1 1/2 gallon of distilled water (no minerals,no rust) will give you -34F protection. |
12-29-2012, 03:35 PM | #4 |
If there is a thermostsat it should be in the top hose
Even though a thermostat was not original from the factory it is a good modification in my opinion, for me it has been worth 2-3 mpg and cleaner oil, I have always used antifreeze year round. |
12-29-2012, 05:08 PM | #5 |
Supplier's parts catalogs can answer SO MANY basic questions! Bill W.
12-29-2012, 06:12 PM | #6 |
12-29-2012, 07:03 PM | #7 |
Don't buy seasonal anti-freeze like I did a few years back. Buy permanent anti-freeze. The seasonal only last for one season. I almost lost a D8 dozer using seasonal.
12-29-2012, 10:32 PM | #8 |
I drain my whole system in the winter....bone dry....And leave the cap off.
12-29-2012, 10:48 PM | #9 |
How does the thermostat give you better mpg?
12-29-2012, 11:00 PM | #10 |
Ha! Aint that the truth... I once rebuilt a transmission using the Snyder's catalog.
Oregon Enduring A's Chapter MAFCA |
12-29-2012, 11:13 PM | #11 |
12-30-2012, 12:36 AM | #12 | |
You're my kind of GUY!! I gave my Les Andrews book & my old yeller service bulletin book to a friend, Model A's ain't hard to put together! Bill W.
