I have a 42 engine in my 40 Sedan Delivery. Right now, the generator pulley is adjusted all the way to the top. This has the fan blade nipping the bottom of the right upper radiator hose. Macs lists this belt as 5/8 x 36. A friend of mine had the same problem and told me that he had the same problem on one some years back and located a shorter belt but he couldn't recall the length. Assuming I'm certainly not the first person to have this problem, can anyone provide the length and hopefully a part number?
Go to your local NAPA store and tell them what belt you have now. They can look up a belt by length and width that should be shorter than the one that you have now.
Take your old belt to NAPA and match it to one that is the same width, but slightly shorter. (Like tdlm... says
![]() Last edited by 4dFord/SC; 11-26-2011 at 07:51 AM. |
I always pay the price when I don't proof read my posts. Excuse my typing. My brain seems to be out of sync with my fingers these days. At any rate... Any help from the experts will be appreciated.
The fan pulley on the later engine, mounts to the generator and adjusts up and down. A shorter belt should pull the fan down out of harms way.
ADDITIONAL INFO: It appears that the wrong belt may have been used on the car. All the listings that I find have the belt width at 7/8". This belt measures closer to 5/8". This places the belt flush into the pulley V groove. Obviously, the wider belt would ride higher in the grove. Can anyone tell me the correct width of the pulley groove at its widest point? How much above the groove should the outer surface of the belt be?
Thanks again for all the help. |
Just realized what my problem may be... I have two different pulleys on this engine. The fan pulley is a wide-belt pulley and all the rest are narrow belt pulleys... I guess my question now is whether or not a narrow pulley can be installed at the fan? This engine is a collection of different parts. It checks out as a 41-42 block. The distributor and fan are typical of a 46 to 48.
I thought a 40 had the fan on the crank pulley. 39 was the last year for generator mounted fans except for trucks. Is the sedan delivery the same radiator/fan setup as the car? Should be a 5/8" belt.
Bill |
