03-28-2024, 02:57 PM | #1 |
48 ford
where would i find the serial/vin# - 1948 ford 4 door sedan
03-28-2024, 02:59 PM | #2 |
Re: 48 ford
03-28-2024, 05:05 PM | #3 | |
Re: 48 ford
03-28-2024, 04:02 PM | #4 |
Re: 48 ford
For vehicles produced in the US, on the top of the driver's side frame rail between the radiator support and the steering box. The stampings are not deep, so use a scotch-brite pad to remove the typical crud as you search.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it Last edited by FortyNiner; 03-28-2024 at 06:08 PM. |
03-28-2024, 06:23 PM | #5 |
Re: 48 ford
This will help: Same as a 47 Ford
http://www.vanpeltsales.com/FH_web/1...eardown-13.htm |
03-29-2024, 10:01 AM | #6 |
Re: 48 ford
03-29-2024, 10:19 AM | #7 |
Re: 48 ford
Most often I have found that the 46-48 Ford ID number is found near the front crossmember.
