01-27-2024, 06:39 AM | #1 |
Rear panhard bar stud
Has anyone replaced the rear stud for the panhard bar ? If so , the best way to do it .
Thanks, Rick |
01-27-2024, 12:56 PM | #2 | |
Re: Rear panhard bar stud
I would assume you are referring to a '46-48 rear end because vehicles earlier than 46 did not have panhard bars.
Bill.... 36 5 win cpe |
01-27-2024, 01:46 PM | #3 |
Yes, thank you
01-27-2024, 02:20 PM | #4 |
Doesn’t it have a pin through it to secure it in the housing?
01-27-2024, 03:20 PM | #5 |
Remove pin, heat perch with fire wrench, beat the piss out of the stud.
01-27-2024, 05:00 PM | #6 |
Rick |
01-27-2024, 07:22 PM | #7 |
The two I have has pins.
01-27-2024, 09:36 PM | #8 |
01-28-2024, 06:47 AM | #9 |
Probably too much paint on mine, thanks , I will find the pin.
Rick |
01-28-2024, 01:36 PM | #10 |
The pix that Ken/Alabama posted in his reply to this thread clearly shows the shock mount on the diff housing. If the pin and/or mount are not clearly visible on the rear end, you possibly have two problems.. One: you don't have a '46-48 rear end or someone cut the mount off.
The oval headed pin that is shown in the pix is actually a large rivet that will require cutting the riveted head off of in order to drive the large rivet pin out and remove the shock stud.
Bill.... 36 5 win cpe Last edited by blucar; 01-28-2024 at 01:43 PM. |
01-29-2024, 09:40 AM | #11 |
Found the pin, thanks guys
Rick |
