11-30-2023, 07:12 AM | #1 |
Putting a trailer hitch on a 41 Pickup
Anyone found a easy way to install or found an receiver style hitch that fit a 41 Pickup ? I am not trying to pull anything heavy, I know all the arguments for and against it including brakes and suspension.
11-30-2023, 08:36 AM | #2 |
Re: Putting a trailer hitch on a 41 Pickup
Check with weedburner 40 over on the HAMB He's done about everything with a 40-41 Ford. He may make a hitch package for your application?
11-30-2023, 03:18 PM | #3 |
I think I have a couple of brackets that bolt to the bumper with a ball. If you're willing to risk your bumper PM me an I'll look for them.
-Scott |
11-30-2023, 04:17 PM | #4 |
That was the main way it was done back when we were kids. I have receivers on a couple of my old fords I uses in my business, but on the woodie I have the 'clamp on the bumper' trailer ball because it just looks right.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
11-30-2023, 04:55 PM | #5 |
Use a angle iron that reaches from one side to the other where your bumper brackets are together. Use two old connecting rod caps, drilling the angle iron for them and bolt the iron. Use a 1/2"by 3" Flat bar welded to the angle that runs under your bumper, drill it for the ball and weld a flat bar to it that extends up to the top of your bumper and drill a hole thru it and your bumper for a bolt. If you do not want to drill the bumper, you can set up some sort of a clamp.
11-30-2023, 11:43 PM | #6 |
Good luck ….. |
