03-02-2021, 02:16 PM | #1 |
Y-Block Spark Plug Wire Grommets
Is it difficult to get the wires through the grommet holes? Seems I've read about difficulties. Any tricks or just slides through easily?
03-02-2021, 02:51 PM | #2 |
Re: Y-Block Spark Plug Wire Grommets
I used wires from Speedway, and grommets from MACS. I peeled the grommets around the wires, they do not slide together. Then assemble the metal parts around the grommets when the wire lengths are correct. They are a bit of a bitch to do, but good parts last a really long time and are worth the effort.
03-02-2021, 02:54 PM | #3 |
It can be a little bit of a struggle. Suggest you slather 'em up with spray silicone lube to help 'em slip through. A pair of 90* needle nose pliers can be your friend but be careful not to pull on the terminals.
Often wrong but never in doubt. |
03-03-2021, 07:45 PM | #4 |
I think mine came with slit in them, and then I put the brackets around em'''
03-04-2021, 10:07 AM | #5 |
