08-01-2020, 06:25 PM | #1 |
Rumble Seat Help
Tinkering with my Roadster while waiting for other parts. My rumble seat "back" cushion isn't fastening to the lid correctly. My lid has 2 slots towards the top on either side and the back cushion has 2 tabs that slip down into these slots, there is nothing on the bottom of the cushion to attach to the lid and subsequently everytime I close the lid the bottom of the back cushion rubs on the seat cushion causing it to raise and the tabs come out of the slots, so when I open the lid next time the back cushion is laying face down on the seat cushion and I have to reattach it every time. What should be on the bottom to hold it in place. Pictures just for reference, not my car, just stolen off interweb.
"I'd rather be sitting in my A Model thinking about God, then in church thinking about my A Model." |
08-01-2020, 07:15 PM | #2 |
Re: Rumble Seat Help
Take the back cushion out, look at the bottom frame of the cushion, there should be two "holes". Now look at the bottom of the deck lid, there should be 2 "D" nuts that take two bolts thru the 2 "holes". Install the seat as you usually do and insert the lower bolts and tighten. FWIW This is if I've remembered correctly.
Paul in CT |
08-01-2020, 09:12 PM | #3 |
That is correct, but in can be a PITA. I ended up securing mine with plastic ties around spring and to rumble lid. Works great and you cant see it.
08-01-2020, 09:22 PM | #4 | ||
08-02-2020, 06:31 PM | #5 | |
06-19-2022, 08:37 PM | #6 |
06-20-2022, 08:34 AM | #7 |
06-19-2022, 10:40 PM | #8 |
I don't know rhe thread size but when I put mine in it had no bolts and fell out as yours did. I crawled in there and looked to find the holes and took a few random bolts with me, got back in and just tried a few until I had two that would screw in all the way, put a lock washer on each, then a flat washer and reassembled the seat back onto the lid. Been there a few years now and I don't find it falling out of the slots at the top anymore.
06-20-2022, 05:40 AM | #9 |
I had the same problem with the back rest cushion. My solution was to take bottom cushion out, put the back rest in place with the top tabs then put the bottom cushion in place with the spring clips in the holes. Lastly push the back of the bottom cushion down in place. This holds the back rest from moving. I do not use any other back rest fasteners. Mine stays fine as the rumble lid id closed.
06-20-2022, 11:20 AM | #10 |
Are there special clips that hold the seat bottom in place? My back is attached fine but the seat bottom moves around.
06-25-2022, 06:46 PM | #11 |
Ok, so I took the seat bottom out and removed the carpet and padding and there are two holes drilled in the floor. The rumble seat bottom frame has two nibs in the from of the frame to fit down into the holes in the floor to keep it from sliding around. Is this how it was originally done?
04-21-2024, 08:12 PM | #12 |
Found this thread that is about the same problem I have. My rumble seat back releases on one side from the lid top when closed. This because one tab rotates and lets the back come loose from the lid. What can I do to freeze the tab in position to hold the seat back tight against the lid?
