03-27-2017, 02:03 AM | #1 |
Post war replacement blocks for 81a
Hi guys,
It's been awhile since I last logged on... I have a post war replacement block for an 81a motor that has a 3/16th bore and is also factory relieved. My question is, how far can these be bored out. One cylinder has a nasty gouge (about 50 thou) from a gudgeon (wrist) pin circlip coming loose and a piece of the pin broke off and gouged the bore. I don't need or want this block, so I'm wondering if there is any demand for these things, or is it just scrap value. The block is in New Zealand so V8 blocks are not as plentiful as the US. Thanks. |
03-27-2017, 05:12 AM | #2 |
Re: Post war replacement blocks for 81a
I would not scrap it. Someone somewhere needs it.
03-28-2017, 01:42 AM | #3 |
03-27-2017, 06:00 AM | #4 |
Ford installed hard steel sleeves in some of the 81A blocks you can do just one cylinder for repair.
03-28-2017, 01:44 AM | #5 |
03-27-2017, 11:18 AM | #6 |
Going for 239 is working to if you want more displacement. If the block is not badly rusted itīs a keeper !! |
03-28-2017, 01:46 AM | #7 | |
03-27-2017, 01:47 PM | #8 |
Your size dimension is a question mark for me. Is it 3 1/16 standard bore for 41A block or is it already out to 3 3/16 oversize? These have relatively thin walls but they will go out to 3.1875" as a general rule. If more than that I would get it sonic tested. If it is still near standard, the bore might clean up on that scored wall. If not, it would be worth sleeving as others have already mentioned.
03-27-2017, 05:10 PM | #9 |
Post war replacement blocks ive seen are 59A castings with small bore....if so definitely a keeper...
03-28-2017, 01:49 AM | #10 |
Yes it is the replacement block but it doesn't have the 59A letters on it. I heard that some US made replacement blocks were designated 41A. But this one would have come from Canada as a Commonwealth countries export.
03-28-2017, 02:30 AM | #11 |
I have a couple of these blocks , both 3 3/16th 60 thou over, you should have plenty of meat left.
03-27-2017, 06:06 PM | #12 |
I have a 59 series long block that was cast in 1953 (stenciled on crate) that is 3 3/16 that came out of a Ford dealership in Texas in 1958. It had 8ba rods, cap screws on mains and 51 crankshaft. I left the bore at 3 3/16, put in a 4" crank and Ross pistons with the skinny rings. This motor is going into a 40 V8 business coupe with 4bbl, and Columbia rear end.
03-27-2017, 08:56 PM | #13 | |
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
03-28-2017, 10:27 AM | #14 |
That should be a C51A block unless it's a prewar C81A casting. They made them for a while after the war but we seldom hear much about them. I don't think the prewar Canadian blocks had the raised casting numbers on the front of the block like they did on the post war C59A and C69A blocks. It would be interesting to know if it has a raised casting ID on there.
The US designation was 41A for the post war 221 blocks and they had many characteristics of the prewar 81A block but most have the 59 on the bell. I think they used pewar type sand cores from the old engines inside the core boxes for the 59 series blocks for production casting. How they could ID them at the factory before painting is a mystery to me. You have to know the characteristics to tell them apart. Last edited by rotorwrench; 03-28-2017 at 10:48 AM. |
03-28-2017, 06:59 PM | #15 |
Thank you gentlemen, you have been very helpful.
