07-05-2013, 03:31 PM | #1 |
Spindle ID?
Remembering getting later spindles for my '36 when converting to hydraulic brakes but don't remember what year they are; I can see a "68" on one of the spindles which would make me think the spindles were '36 but they bolt directly to the later backing plates without adapter rings. I would like to sell these spindles but not sure what year to advertise them as. Thanks
07-05-2013, 11:20 PM | #2 |
Re: Spindle ID?
A picture paints a thousand words!!
07-06-2013, 09:21 AM | #3 |
Re: Spindle ID?
The '36s have a longer "snout" so the hub/drum won't seat to the backing plate if later hardware is used. They'd be good for the '36 only person.
Luck occurs when preparation and opportunity converge. |
07-07-2013, 11:08 AM | #4 |
Re: Spindle ID?
Never could figure out to post pic. on this site; thanks for resonding.
07-08-2013, 09:45 AM | #5 |
Re: Spindle ID?
If your spindles bolt directly to later style backing plates with NO spacer ring they are anywhere from 37-48 style. I think the 68 you see is actually a 78. To correct another post the 36 spindles have the shorter snouts and will accept the later drums with no bearing spacer.
dickspadaro.com |
07-08-2013, 10:42 AM | #6 |
Re: Spindle ID?
07-08-2013, 03:24 PM | #7 |
Re: Spindle ID?
Uncle Bob, the snout length on the 36 spindle is the same distance as the 37-48. The difference is in the drums and the backing plates. The index is different with the 35/6 brake surface centering further inward than the later 37 and up style so the 36 hub has a longer snout to index the braking area further inward.
dickspadaro.com |
