05-27-2015, 12:16 PM | #1 |
59ab generator question
Been test running this 59ab in my panel but today I put a radiator in front and filled it, got belts on and dealing with drips. I am running it on a 12 volt battery and coil with resistor. With the generator now in the loop, isn't there a wire I need to run to ground so the generator doesn't get cooked. Friend is coming by soon to make a quick youtube video of what won't exactly be the first fire-up, but could be of the first driving experience. Don't wanna fry the gen because I may stick with the 6 volt system. Thanks
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
05-27-2015, 12:40 PM | #2 |
Re: 59ab generator question
I run a 6v gen on 12v I just change to a 12v regulator,i would disconnect the regulator to be safe as you might fry it
05-27-2015, 04:11 PM | #3 |
But just to take a run around the place is it ok for a while to just run with the 6v gen unwired? If I do go 12 volt it will probably be with an ugly alternator.
05-27-2015, 06:33 PM | #4 |
That should work for you. All you need from the battery is enough juice to supply the coil primary.
Alan |
05-27-2015, 10:19 PM | #5 |
Why go to an ugly alternator? Use the armature and both end plates of your 6v gennie with the field coils from a 1957 Y block Ford. I just used the whole barrel, fits fine, looks stock, charges great. No ugly alternator for me. Don't forget the 12v regulator.
05-27-2015, 11:07 PM | #6 |
