Old 01-13-2012, 11:32 PM   #1
Rascal
Rascal's Avatar
Cool Ford 1938 pick up steering box & front axle interchange.
what appears to be A 3/4 ton 38 v8 truck chassis [long parallel 6" deep frame ] has been offered to me & pics were supplied. it has i beam, cross spring, radius rods-A frame , steering box etc.
my question is :
Does the 1938, 3/4 ton truck steering box interchange with the 1/2 ton pickup frame?
IF the S/box casing & mounting plate appear to be the same will they fit the pass car & 1/2 ton p/u frame?
another question is :
are the 3/4 ton I beam axle , cross spring & wishbone ,the same in dimentions as pass car & p/u original items.
in photos I can see the back plates- brakes & drums are definatlly slightly bigger & the Rims look to be 17" & 5 lug x 6" centres with a split ring saftey band on the rim,
Last edited by Rascal; 01-14-2012 at 05:36 AM. Reason: to further clarify my question.
Rascal is offline   Reply With Quote
Old 01-14-2012, 12:37 AM   #2
NealinCA
NealinCA's Avatar
Default Re: Ford 1938 pick up steering box & front axle interchange.
If it has 17" split rims, then it's a Tonner. 3/4 ton trucks used 16" wide 5 wheels.
NealinCA is offline   Reply With Quote
Old 01-14-2012, 05:23 AM   #3
Rascal
Rascal's Avatar
thanks for the response.
you will see, i have re-phrased my question a little but am still a little baffled as the frame has wishbone front end with cross spring & what appears to be pass car - p/u I beam . did only the 3/4 tonners have these?
i was certain that one tonners had 1/2 elliptic springs all round
Old 01-14-2012, 02:31 PM   #4
NealinCA
NealinCA's Avatar
FYI, 3/4 tons didn't come out until 39. It sounds like this one has a tonner rear end, as 3/4 tons had 16" 36-39 type wheels all the way around.
As far as I know, the front end is all the same as passenger and 1/2 ton. My brother has a 39 3/4 ton...I'll ask him to make sure...or maybe he will chime in.
Neal
Old 01-14-2012, 03:07 PM   #5
Rascal
Rascal's Avatar
Thanks neil.
yes, this has tonner rear axle housing [not banjo] is 1/2 elliptic -parrallel leaf springs & has radius rods about 12" out from brake back plates, these are clamped around the housing. everything looks original
and not fabricated on, so i assume its factory.
The steering box query is my main concern , but id on the other items is always very helpfull.
cheers . Russ.
