02-01-2024, 10:38 PM | #1 |
Source for 42-48 Emergency brake cable
I read some old threads that the reproduction cables have the wrong springs. Is anyone selling the correct cable now?
Thank you |
02-02-2024, 03:09 PM | #2 |
Re: Source for 42-48 Emergency brake cable
If you are referring to the rear cable, the springs are correct in appearance. The issue? The springs are too long. Easy enough to cut them off to the proper length.
02-02-2024, 05:01 PM | #3 |
I have a 46 4 door sedan parts car. What model do you have?
Carlos Marquez 48 Ford Sedan 57 Ford Skyliner |
02-02-2024, 05:29 PM | #4 |
02-02-2024, 06:14 PM | #5 |
All models are certainly not the same. There are different lengths.
02-03-2024, 10:09 AM | #6 |
02-03-2024, 10:30 AM | #7 |
Only one length for 42 - 48. That is correct.
02-05-2024, 12:26 PM | #8 |
02-05-2024, 05:36 PM | #9 | |
I believe I still have the new, aftermarket '40 cable in my stash if anyone can use it. |
