08-01-2020, 06:18 PM | #1 |
Manifold
Has anybody had any luck with resurfacing their intake & exhaust manifolds, I think I have Warped one
08-01-2020, 06:52 PM | #2 |
Re: Manifold
You really should resurface them but keep them bolted together (2 bolts) at the heat riser. If they have been resurfaced several times before you may lose the ability to use your gland rings in the exhaust ports. It is very common for the exhaust manifold to "droop" near the outlet, sometimes so severe that you will not be able to hold a gasket. I have had the best luck with a copper gaskets.
Steve - Santa Rosa |
08-01-2020, 07:10 PM | #3 |
Re: Manifold
Use the late '31 2 piece copper gaskets. JMO
Paul in CT |
08-01-2020, 07:40 PM | #4 |
Re: Manifold
I wrestled with a warped/sagged exhaust manifold last year - could not get the gland rings to seat or get the copper manifold gasket to seal without the gland rings. I finally bought a new exhaust manifold from Bratton’s - problem immediately solved. I had a local machine shop plane it and the intake manifold assembly bolted together. The exhaust is quiet - no leaks, gland rings all fit, and the new manifold seems to be very well made.
08-01-2020, 09:12 PM | #5 |
Re: Manifold
I have not tried it but I have heard of mounting the manifold that has sagged up side down and heating it really hot and putting a weight on the exhaust end and letting it sag back into proper alignment. Also I heard that the manifolds with the extra metal for heaters, autolite I think, are not supposed to sag as badly as the extra metal provides more support, though I think I have seen them sag, don't know.
08-01-2020, 09:16 PM | #6 |
Re: Manifold
08-02-2020, 07:06 AM | #7 |
Re: Manifold
I recently bought a new one from Snyders as the two originals I had were unusable due to the boss behind the threads being knocked out (would have caused an exhaust leak). I ground some of the casting lines off and cleaned it up - now it looks original but performs like brand new!
"The more things change, the more they stay the same." |
08-02-2020, 09:14 AM | #8 |
Re: Manifold
Sunnybrook Farm, I did the upside down/heating trick. I worked but didn't last. The manifold 's heating/cooling history cycle made it return to the warped position. Round filed it & bought a new one, problem solved.
08-02-2020, 09:18 AM | #9 |
Re: Manifold
Unless it’s show buy the new combo intake and exhaust manifolds. Use gland rings and 2 piece copper show gasket. If you can, add the aries exhaust. You will have a leakless system and a model A sounding like it should
08-02-2020, 11:27 AM | #10 |
Re: Manifold
Something to consider!!!!
Before I had my engine rebuilt I had a heater manifold on it. Had engine re-builder surface side of block in area of manifolds. Also had a local machine shop surface the heater manifold along with intake. Was trying to get everything Perfect! Well now I am unable to install the cover of the heater manifold because it will not pass by the distributor! |
08-02-2020, 11:37 AM | #11 |
Re: Manifold
I had to replace the exhaust manifold recently it had sagged 3/8 of an inch at the back.I purchased a new one bolted the manifolds together and ran a straight edge across them looked darn good installed them with copper gasket and gland rings mission accomplished.
08-02-2020, 06:43 PM | #12 |
Re: Manifold
Thanks for the info
