07-11-2020, 06:28 PM | #1 |
Installing stainless trim on 46 runningboards
Ok,I've used half a bottle dishwashing soap to help slide this stainless on. It will go 10-12 inches and it stops. Rubber feels smooth but may try some 320 sandpaper with detergent to smooth it more tomorrow. Any suggestions???
Thanks |
07-11-2020, 07:38 PM | #2 |
Re: Installing stainless trim on 46 runningboards
I never have slid them on. Usually line them up on the length of the board and slap (press) them in place. They will snap in place with out too much force. This was done on NOS running boards and NOS trim. This may have made a difference.
07-11-2020, 08:36 PM | #3 |
THANK YOU!!! I have been sitting here thinking about doing that tomorrow. Makes sense but didnt know if I would be able to pull it up on top of board once it was latched on lip(bottom edge of board). Thanks for the advice
07-12-2020, 09:25 AM | #4 | |
I guess this doesn't help much. John |
07-12-2020, 10:54 AM | #5 |
Suggest hooking trim on bottom lift up hard and at the same time snap the top onto the board .use the palm of your hand , lift and snap. might not hurt to spray cilicone on rubber first
07-12-2020, 11:06 AM | #6 |
07-12-2020, 12:26 PM | #7 |
I should have mentioned,they are off the car. Thanks again,will have em on later today!!
07-12-2020, 06:18 PM | #8 |
If you use silcone I hope you don't plane to do any paint work on the car. You will regret
using it if you do. This is comming from someone that had done collision repair and painting for over 50 years and a collision repair shop owner for over 45 years. I did not allow silcone either inside my shop or outside of it. |
07-12-2020, 07:53 PM | #9 |
No silicone,dishwashing soap. Worked great,job done. Thanks guys
07-06-2023, 05:11 PM | #10 |
Hi 46woodie, I'll be tackling my runningboards this Fall and would love to pick your brain and learn from your experience. I have a 46 woodie also. Are you in the NWClub member directory?
07-06-2023, 07:17 PM | #11 |
r-horn, if you're located in the north east the NWC Nationals will be held at the Mystic Seaport in CT the weekend of July 22nd. Should be 50 to 75 Woodies.
07-06-2023, 08:46 PM | #12 |
Hi woodiewagon46, I'm located on the west coast and we just held Woodies on the Wharf. Attendance was around 145 cars, down from the usual 170ish. It was a beautiful day with beautiful cars, and the people weren't bad either. I hope you have a good show at Mystic. I've attached a couple photos from WOW.
07-06-2023, 08:59 PM | #13 | |
