12-29-2017, 12:49 PM | #1 |
identifying an H.C. head, How?
On one of my coupes, I have a indistinguishable looking head. It runs pretty good so I'm suspicious that someone put a HC head on it. But I don't know. Do the after market manufacturers use some sort of marking system so their heads can be identified at a later date? The engine runs fine so I don't want to rip it down at this time.
Terry |
12-29-2017, 01:20 PM | #2 |
Re: identifying an H.C. head, How?
Check the compression.
12-29-2017, 02:58 PM | #3 |
Take some photos especially any markings on the head and post them. Maybe someone will recognize something. You could also find out by running a compression test.
Charlie Stephens |
12-29-2017, 08:13 PM | #4 |
Stock heads from Ford have a tiny bump just above the water pump below the water outlet. Snyder heads have 2 bumps on the driver side with 5 small pin pricks in each. Brumfield heads are marked with a B-F. Ford police heads have a large B or C cast in them. Other than that all bets are off and you will have to remove the head and check the combustion chamber. I have seen heads with several different names cast in them such as the lion head and a Hoof head I have. There are many aluminum heads with varying compression ratios such as the Thomas and cyclone heads among many others.
http://www.model-a-ford-4bangers.com/ |
12-30-2017, 11:17 AM | #5 |
So, what is the expected compression for a stock head?
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
12-30-2017, 11:55 AM | #6 |
Terry |
12-30-2017, 05:59 PM | #7 | |
I installed a new Snyder 5.5:1 head last August in my '29er. A compression test then resulted in 75# plus/minus 1# for each cylinder. Mike in Orygun |
