04-14-2019, 07:29 PM | #1 |
Installing piston rings
years ago I read an interesting article, with illustrations on how to best install piston rings by the original "Honest Charley" I saved the article with it's clear illustrations on how to orient them. Naturally, when I go to use it I can't find it. Anyone have a copy they could post. Thank you Fordbarners.
04-14-2019, 09:15 PM | #2 |
Re: Installing piston rings
Installing rings is pretty much a standard deal on most engines - you orient the gaps to be spaced around the circumference - such that they are not in alignment. The only other thing to think about with a flathead is that if you happen to have a relieved block, it sure makes installation easier if you don't have any ring gaps in the relief/transfer area . . . such that you have less issues with the ring popping out and potentially breaking it in this area. I pay REAL close attention to the relief area - as my ring compressor does not "dip down" into the relief, so it is easy for a ring to pop-out and get hung up. My favorite tool to coax them back in - is a wooden paint stick!
04-14-2019, 09:36 PM | #3 | |
The obvious exception would be staggering the rails on the oil rings to hold the ends of the expanders in place. If you're using old one piece oil rings, treat them like compression rings. It doesn't matter where the the gaps are. But do follow the instructions regarding which side faces up. |
04-14-2019, 10:24 PM | #4 | |
04-15-2019, 05:19 AM | #5 |
Thank you '51 Merc. That's the one I was looking for.
04-15-2019, 05:44 AM | #6 |
04-15-2019, 08:03 AM | #7 |
5 & 7 O'clock, been doing that for years. But as John says, who knows??
04-15-2019, 08:27 AM | #8 |
AM or PM?
04-15-2019, 08:46 AM | #9 |
As JWL says, they move. So much for Honest Charley's theory. Thank you all.
04-15-2019, 06:59 PM | #10 |
This was sent to me from Craig from Grant rings. Take it as you will .
Ring Gaps vs Knowledge Gaps During school summer holidays there occurs a period known as the "silly season" when breaking news is slack and newspapers, radio and TV issue forth all sorts of drivel to justify their existence. In our industry I sometimes think that we use ring gaps to fulfil a similar purpose and we do it all year round. There are more old wives tales about ring gaps than any other facet of our job, so lets spend a while and bin a few of them. Frequently I hear in court that when an engine is dismantled it is discovered that the ring gaps were not staggered when they were installed. Frequently I read workshop manuals that go into great detail on the necessity to stagger ring gaps. Frequently these manuals specify ring gap limits which is yet another myth we can bin before we are finished. In days gone by, some compression rings used to have a threepenny bit expander behind them. These braced against the base of the ring groove and forced the ring onto the cylinder bore but these are very much the technology of yesteryear and, as such, an exception to what I am about to say. Piston rings are free agents and can rotate or not rotate as they see fit. They are not in touch with the base of the groove and neither are they trapped between the upper and lower faces of the groove. The rings are entirely free to rotate except where a stop peg is fitted so what's the point in staggering the gaps on installation? We used to work on a minimum of 0.020" back clearance on radius or, to put it another way, the inside diameter of the ring when installed in the cylinder must be at least 0.040" bigger than the groove root diameter. Minimum side clearance was generally held to be 0.0015" and if you could fit a 0.006" feeler gauge in the groove along with the new ring then the groove was "goosed" so the piston was replaced. The piston ring was manufactured with a tangential load the force with which the ring presses against the cylinder wall but apart from that it is completely uncontrolled. There is no way, under these circumstances, that you could prevent the ring from turning so, to repeat the question, why stagger the ring gaps on installation? Staggering ring gaps when installing pistons is every bit as daft as having four tyres fitted and placing all the valves at "twelve o'clock". One trip to Tesco and they end up all over the place. Equally daft are those who expect ring gaps to stay staggered when the engine is in operation. When there is clearly nothing to prevent the ring from rotating, why should the gaps stay staggered? More than one county court judge has fallen for the hocus pocus that because the gaps were in line when the engine was dismantled, they must have been in line when installed. Absolute poppycock! Yet the inclusion of such rubbish in workshop manuals does admittedly give it an air of authority. When you think about it, you don't need me to tell you but I will anyhow that rings do rotate in operation. Every now and again the gaps do line up and once lined up there is a tendency for them to stay lined up at least until the vehicle hits the next pothole in the road when one or other will rotate and break the line. Staggering ring gaps when installing rings is a myth that we can bin forthwith. Even worse is the preoccupation with the size of the ring gap. Yes, there is a minimum but this varies considerably depending on the material used. Normally 0.003"/0.004" per inch of bore size is given but where, for example, low expansion SG (spheroidal graphite) iron is used, it can be considerably less. Its no problem if the gap is too small because it can, in the final analysis, be filed bigger but what do you do if it's too big? You cannot stick a bit extra in there! Well, the answer to that was that you melted them down and started afresh until AE research asked the question, "What is too big?" and set out to quantify that. The results were interesting very interesting and what you are about to read was kept quiet because it bestowed an enormous commercial advantage on AE. This is probably the first time the information has been published although the research was undertaken in the late 1970's almost 25 years ago. A Ford Kent engine was stripped and fitted with compression rings which had end gaps of 0.015" when fitted in the bores. The engine was wired up with the usual telemetry to measure blow-by and oil consumption and then run in one of the test cells. After making due note of the blow-by and oil consumption, the engine was stripped and fitted with new compression rings with gaps of 0.025" and the test cycle repeated. These rings were subsequently replaced by ones having end gaps of 0.035" and the test cycle repeated again. It had been planned to stop at 0.035" gaps ----------> but the results were so interesting that it was agreed to proceed to 0.045 and then not to 0.0055 but to 0.0625 1/16"! Whoever heard of rings with 1/16 gaps a ridiculous figure but the interesting thing was that the increase in blow-by and oil consumption at 0.0625 was only marginally above the figures obtained with 0.015 gaps. Practical tests established that the gap was not the villain of the peace. To all practical purposes the size of the gap didnt matter. It is important to stress at this point that we were dealing with compression rings that were brand new when fitted to the test engine. The gap was specially manufactured for the tests. So how come all oil burners and heavy breathers have ring gaps you can back a bus through? Well, the tangential load that the ring exerts onto the cylinder wall is a direct function of its radial thickness. As the periphery wears in contact with the bore, the radial thickness obviously decreases, as does the tangential load. Peripheral wear means a smaller ring o/d and this manifests itself as an increase in the ring gap. So, whilst all oil burners and heavy breathers have big ring gaps, it's not the gap but the reduced tangential load that is detrimental to the performance of the engine. The ring gap is a complete red herring. Imagine four top compression rings all with 1/16 gaps. The total gap for all four would be 1/4. Now imagine the seal provided in an 80 mm diameter bore. Pi x Diameter = Circumference, so we have 3.14 x 3.15 = 9.891. Multiply that by four cylinders and we have 39.564 over a yard of contact seal between piston rings and bore. Now visualise the many litres of blow-by and consider whether all the gas is squeezing through 1/4 of total gaps or passing through 39½ of reduced pressure contact seal! But even this ignores one important facet of the argument because there is not just the one compression ring on a piston there are usually at least two and that is because rings work as a team to form a labyrinth seal. For gaps to be the villain of the peace, the gas would have to find the gap in the top compression ring and pass through. It would then have to circulate to find the gap in the second ring and pass through that and so on. Now this may be possible if the power stroke lasts for 10 minutes but it doesn't, does it? At 3,000 rpm the power stroke duration is a mere 1/100second. Quite simply, the power stroke does not last long enough for the combustion gas to find its way around the maze or labyrinth seal, so the villain of the peace has to be the reduced tangential load of the ring on the bore caused by peripheral wear or reduced radial thickness of the ring. This was our hypothesis based on the results obtained in the engine test cell but it took a very clever American to prove it. This genius invented telemetry that measured gas pressure between the piston rings in a working engine. Use of his brainchild revealed that some gas did get through the top ring gap sufficient to generate a hell of a pressure between the top and second rings so it clearly was not finding the gap in the second ring. The labyrinth was working well. Caterpillar and IHC must have thought it was working too well because they increased some second ring gaps to 0.050 and 0.070 thought to be beneficial. Come to think of it, the exception proves the rule as usual. Two stroke engines would not need stop pegs to prevent the end gap from crossing a port if the ring didn't rotate. The people who allege that ring gaps were not staggered when installed just because they are in line when the engine is dismantled don't need stop pegs. They could simply position the end gap away from the port and expect it to stay there and we all know that this would get them into more hot water than a Yorkshiremans tea bag! So why do they always blurt out their rubbish on the importance of staggering gaps? The very presence of a stop peg also proves my point about the size of ring gaps. Where a peg is fitted, the end gap has got to be 1/8 to accommodate the peg. There would be one hell of a draught through that if the 0.015/0.018 boys were correct. This knowledge was commercial dynamite because, instead of the '0.015/0.018 spec., it meant that new rings with gaps over 0.018 could be used without any detriment to the engine's performance. The gap was only detrimental when it was the result of peripheral wear. Customer acceptance was the only problem. To re-educate the customer would let the cat out of the bag, thereby losing the distinct commercial advantage. It was decided, therefore, to accept rings with gaps of up to 0.030 in a nominal bore but even then there were arguments. 0.030" in a nominal bore is 0.045 in a bore worn by 0.005 and it's normally engines with this sort of wear that get new rings. The gaps on the new rings were bigger than the gaps on the ones being replaced which led to several heated conversations and how the hell do you pacify the customer and keep the cat in the bag? It made diagnostics a lot harder too because when all rings set off in the 0.015/0.018 area gaps of .040 meant something but now, when you don't know what they set off at, what they measure is meaningless. Well, now you know. All rings are free agents to rotate as they like, making staggering of gaps on installation a joke and ring gaps are not a problem provided that the gap is not the manifestation of reduced ring radial thickness caused by peripheral wear. In the light of the logic expressed in this article we are offering an expensive prize to anyone who gives us a good reason for staggering ring gaps on installation a free burial at sea. M H Booth F.I.Diag.E
"Came too close to dying to stop living now!" |
04-15-2019, 07:41 PM | #11 |
Makes sense to me. The only thing I have ever done is to make sure that the gaps were not in line with each other and that probably is wasted effort.
04-15-2019, 09:14 PM | #12 |
Its a tough one . I remember at the engineering shop the head mechanic there showed me paper that came with rings from someone else that showed the positions to be installed... Its hard to believe that they wouldnt move tho'...
04-15-2019, 10:13 PM | #13 | |
Ask your fellow at grant rings for their installation instructions. That info he sent you is not from a ring manufacturer. Not the best description for installation. R |
04-15-2019, 10:16 PM | #14 | |
04-16-2019, 07:28 AM | #15 |
some thoughts;
I prefer to "clock" the rings per engine manufacturers instructions because of the initial startup to "load" them properly during the crucial 1st few minutes of the break in. Even Grant publishes a "preferred" ring end gap in their packaging. Sure (as the writer claims) an engine will run and not burn too much oil with an excessive end gap but why go thru all the expense of building an engine only to get sloppy in the area of cylinder sealing?? I don't buy it, it's a matter of having an engine "run" vs owning one that will perform to the best of its ability and justify such an expensive project. Most engine builders I know would laugh this guy right out of their clean room. |
04-16-2019, 08:40 AM | #16 |
I know in my head that the placement of the gaps doesn't matter. My heart, however, causes me to stagger them properly when I assemble an engine.
04-16-2019, 09:59 AM | #17 |
In other words, science vs. imagination (wishful thinking)! A lot of what we do seems to be based on imagination rather than scientific facts (and our flatheads keep on running in spite of us!).
04-16-2019, 10:36 AM | #18 |
I've learned to install the rings by manufacturers instructions first for proper placement and second, I always stagger them to start out on an overhaul. If nothing else, this is to get good compression for start up and initial break in.
I do compression checks at each 100-hours of operation on the aircraft engines and since most of them are Lycomings, I go by their service instructions. We use differential compression testers so the readings are actual compression versus 80# input psi. The limits for Lycoming is no more than 15 psi split and no less than 65 psi for service. Leakage noise at intake or exhaust will tell if it's a valve. Leakage that pressures up the crankcase is from the rings. This would be harder to check on a car engine but not impossible. It would be easier on an 8BA with the oil filler and draft tubes blocked. I find the rings line up at no particular interval but they do line up and give low readings now and then (less than 65 psi). I always test run the engine for a while and then recheck the low cylinder. 9 times out of 10, the compression will be back to normal. If it isn't, we will hover the aircraft for a while and then recheck. If it's still low then it's time to remove a cylinder and find out why. |
04-16-2019, 11:06 AM | #19 |
I always understood that the rings move around, but it still seems like good practice to stager them for the initial installation. Don't think you would want all of the ring gaps lined up during the break in process.
04-16-2019, 02:53 PM | #20 | |
At 2,000 RPM cruise, the compression stroke lasts only .06 seconds (six hundredths of a second). |
