11-30-2013, 03:29 PM | #1 |
dipper or no..Q
I have a B block and rods that have new poured babbit at .010 under.
Situation is that the old guy cut the dippers off of the rod caps and plugged the holes. He was setting up for OHV. Question: I can unplug the holes on rods, but do I have any alternatives regarding the dippers, i.e.- can be run without dippers; can new dippers be put on somehow; get new/diff caps w/dippers What you engine builders suggest, thanks ! Last edited by hardtimes; 11-30-2013 at 03:48 PM. Reason: ............... |
11-30-2013, 03:54 PM | #2 |
Re: dipper or no..Q
You need the dippers unless you are going full pressure, otherwise the caps won't get any oil in them. So I think you will need new caps or full pressure to the oil system. Just my thoughts, but I could be wrong.
Mike
11-30-2013, 04:42 PM | #3 |
Re: dipper or no..Q
Take off a rod cap and see if there is a hole in the crank. If so you probably have a pressurised system. You may be OK as is but I would rotate the oil pump to confirm oil comming out of the crank at the rod. Ron W
11-30-2013, 06:41 PM | #4 |
Re: dipper or no..Q
If you don't have a pressure oiling, then you will need the dippers.
You can make some out of sheet metal and hold them on with the rod bolts. I've seen that done on T engines to improve the oiling to the rods. |
11-30-2013, 06:51 PM | #5 |
Re: dipper or no..Q
You can also drill and thread in some 3/16 tube to the caps and then shape the tube
that what a mate did when his where ground off by his balance guy that engine been going fine for years |
11-30-2013, 07:22 PM | #6 |
Re: dipper or no..Q
It can be done but you have to be very careful to recreate the shape and angle of the original dippers. |
12-01-2013, 12:00 AM | #7 | |
Re: dipper or no..Q
I can still work at full pressurizing and will need a B/C crank to drill ? Just exploring options and sheet metal dippers sounds good at this point. Anyone have a good detailed schematic for full pressure piping a B engine ...pictures maybe ? |
12-01-2013, 01:52 AM | #8 |
Re: dipper or no..Q
Use dippers for 30's Chevrolet. that is what they use on T rods. Some T shops carry them. Try Langs.
12-01-2013, 03:20 AM | #9 |
Re: dipper or no..Q
12-01-2013, 08:47 AM | #10 |
Re: dipper or no..Q
29/30 Chevy rods had the dippers made on the rod like an A/B. The dippers for a T won't work since the bolt spread is way smaller. You might use a T dipper and fashion some to work.
http://www.model-a-ford-4bangers.com/ |
12-01-2013, 01:40 PM | #11 |
Re: dipper or no..Q
These are Lang's
Bob |
12-02-2013, 12:54 AM | #12 | |
Re: dipper or no..Q
Thanks for your input...as that info will likely save me some $, time and heartache. I was just about to order from Lang ! I still like the idea of fabricating something. But, hey...maybe I should just go buy a 4/5K OHV head and use the dipperless B rods as is |
