04-28-2024, 12:50 AM | #1 |
226 engine reading 80# of oil pressure
Hi Guys, today I noticed that my F1 with the original 226, that hasn't been rebuilt was reading 80 of oil pressure, I don't believe it should be that high ?. Should I be worried or drive it awhile to let it warm up to see if it will come back down, I just fired it up a few weeks ago, to get it ready for spring and summer driving, Didn't notice it a few weeks ago,
Any help would be great. It doesn't skip a beat while idling. Just high oil pressure Sent from my Celero5G using Tapatalk |
04-28-2024, 04:23 PM | #2 |
Re: 226 engine reading 80# of oil pressure
Hey Cody, good to see you showing back up. I wish I knew what to tell you. What was the OP in the past? Maybe you have a clogged oil passage or a stuck relief valve. I don't think there's any harm driving like that, but I've been wrong before. Maybe a dose of seafoam or marvel in the crankcase is in order?
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
04-28-2024, 04:24 PM | #3 |
put a known mechanical gauge on the engine and then tell us the OP
04-28-2024, 04:27 PM | #4 |
First thing I'd do is get it fully up to temp and see what it reads. If still high I'd plumb in a mechanical gauge and see what it says. I think it's very unlikely to have 80 warmed up.
"It don't take but country smarts to solve the problem" (Smokey Yunick) '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302 |
04-28-2024, 04:41 PM | #5 |
I looked in the owners manual and it shows 50psi @ 2000rpm.
04-28-2024, 05:57 PM | #6 |
Are you sure you have power to the gauge? |
04-28-2024, 06:43 PM | #7 |
Run it to temp, it will drop if the sender works.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
