01-01-2023, 08:18 PM | #1 |
What is this Head
I have a head on a 28 engine that has 06-4 cast into it. Does anyone know if this is a high compression head and if so what is the compression?
Thanks |
01-01-2023, 09:57 PM | #2 |
Re: What is this Head
That looks like a date code June 1934???? Model B head??? 3 bolt (Model B) or 4 bolt (Model A) water pump?
01-01-2023, 11:46 PM | #3 | |
As for the engine it is a 28 and from the looks of things it does not appear to be re-stamped......do not ask me how I know lol |
01-02-2023, 11:37 AM | #4 |
You need to answer the question, does it have a 4 bolt water pump or a 3 bolt water pump? That will tell you A or B
01-02-2023, 06:31 PM | #5 |
It's a 4 bolt water pump.
01-02-2023, 10:16 PM | #6 |
01-02-2023, 11:01 PM | #7 |
01-03-2023, 09:07 AM | #8 |
Your cylinder head is an aftermarket service part that was cast by a forging shop in June of 1940. I have had several heads with casting dates on them, and they have all had the stock compression ratios, 4.2:1 for the Model "A" and 4.6:1 for the Model "B". There is no apparent feature on the current 5.5:1 and 6:1 reproduction heads that shows them to be other then stock.
If the water pump attachment has 4 holes, the head is for a Model "A". If the head has 3 water pump attachment holes, it is for a Model "B".
Bob Bidonde |
01-03-2023, 11:13 AM | #9 | |
01-04-2023, 06:24 PM | #10 |
The model A head with a large cast B on the top of the head is the police head. This head uses the 4 bolt water pump.
The Model B head has a large C cast on top of the head and uses the 3 bolt water pump. |
01-05-2023, 12:27 AM | #11 |
Do a compression test and give us the numbers, if their all even we can take a WAG
(wild ass guess) |
