04-16-2018, 12:34 PM | #1 |
Are these Model T or Model A Subrails?
Hey fellas! How sharp does your brain feel, today?
Prior to seeing these rails, I had heard they were for a 30/31 A. I need some because my car has none. A quick look and I knew they weren't. Still, I'd like to know what they are. The toe area is similar to my T roadster. It has firewall to frame brackets, too. The sill plate is like an A sedan. So, what exactly am I looking at here? Last edited by Brent; 04-16-2018 at 03:38 PM. |
04-16-2018, 01:05 PM | #2 |
Re: Are these Model T or Model A Subrails?
Those are A rails for a two door. See the seat connections so the seat can be rotated forward to let rear seat passengers in.
04-16-2018, 02:05 PM | #3 |
Does not look like any A frame rail that I have ever seen. I have a tudor and this is not it.
04-16-2018, 02:17 PM | #4 |
Not chassis frame, subframe also called sub rail here by OP. 1 thing that strikes me as odd, in picture 2 of 6, the triangular filler with the large hole under the dash brace. Never saw that on an A. Any assembly plant #'s on front crossmember, left side?
04-16-2018, 02:51 PM | #5 |
Okay "subframe" assembly, got it. I have similar/same dash braces on my 26 T roadster. However, the sub rails are different. Could this be 28 stuff? The front width is wider than my 26 firewall but narrower than my 30/31.
04-16-2018, 06:53 PM | #6 |
04-16-2018, 08:31 PM | #7 |
1926 to 1927 were all steel bodies, including, sub rails, just like the 1928 Model A's.
Before 1926, they were all wood, Herm. |
04-16-2018, 08:46 PM | #8 |
Looks very close to a 26-27 two door sedan. But you might be right about 28.
04-16-2018, 08:52 PM | #9 |
After looking at some pics, I think it's a 26/27 Tudor sedan subframe. |
04-16-2018, 09:13 PM | #10 |
Are the front seat pivots on any A's made like that? Both my old 29 and my 31 have forged eye bolt types.
04-17-2018, 12:17 AM | #11 |
The subrails are 26-27 T Tudor, note the aluminum door sill plates and the metal plates that turn to hold the wooden floorboards in place. Bob .
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical. |
04-17-2018, 10:29 AM | #12 |
Thanks everyone!
04-17-2018, 11:53 AM | #13 |
I have been working on and off for the last year,on an old friends 27 sedan. He was missing the very back subrail. I knew those looked familiar. Good luck on your project Brent.
