04-19-2017, 05:47 PM | #1 |
tire/wheel fit on a '55
I have a WWW problem on my new-to-me '55 Ford. The last owner put 255/60R15s on 8" rims on it. They did a masterful job of measuring for the installation as the tire has about 3/4" clearance on the outside fender and just misses the spring on the back side. You can imagine how and when it scrubs. I'm OK with replacing them with 205 or 215 tires, but really would rather not buy/paint new wheels. Any educated guesses on if the 8" wheels would pass under the wheel well? I found that 7.5" is the most recommended for the tire, but I think the 8" would be safe. OH yeah, that's not my shop in the picture. Mine isn't that clean.
04-19-2017, 07:50 PM | #2 |
Re: tire/wheel fit on a '55
I'm running 255/60 15's on 7" rims, 4" backspace on my 55 bird. They're really tight, but they don't rub. I'm pretty sure I wouldn't make it with 8" rims, even if I could get more backspace. I'd be concerned about 205's or 215's on rims that wide, both for clearance, drivability, and looks. Particularly with wide whites, they may not look right spread that far.
I realize you've got a full size car, but you're rubbing already. How they work like that, I'd have to leave to someone who's tried it. I just don't like mounting tires outside, either way, of the recommended spec. |
04-19-2017, 09:15 PM | #3 |
I see you have two different tires on the rear, and it looks
like the right tire is wider than the left, what's the story .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN What I GOT DONE TODAY... I put my rear-end in the recliner, and now I'm going to rest up & watch TV. |
04-19-2017, 09:39 PM | #4 |
You got me there. This picture was sent by the seller before I bought it. Both rear tires are like the one on the right side. The left tire looks like the one in the trunk for a spare.
04-19-2017, 09:41 PM | #5 |
----------Oh
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN What I GOT DONE TODAY... I put my rear-end in the recliner, and now I'm going to rest up & watch TV. Last edited by Lanny; 04-25-2017 at 10:11 PM. |
04-19-2017, 10:25 PM | #6 |
Yes that's a lot of tire and wheel in a spot they weren't designed for, but if the bushings are old replacing them is a good idea anyway. Maybe some HD urethane shackle bushings are available, they might be even better. . Last edited by dmsfrr; 04-20-2017 at 10:41 AM. |
04-20-2017, 12:23 AM | #7 |
I selected P215-75R15 tires for the rear based upon a comparison of readily available modern tires that would closely match the outside diameter of the OEM 710x15's so that there would not be a large disparity in the speedometer reading, AND that the tire would actually fit the width of the wheelwell without rubbing against anything. The mfrs suggested rim width for these is 5.5"-7". You can buy them with wide whitewalls if you want to pay extra $$$. They are difficult to get in the rear, and the jack needs to go all the way up to do it. Very dangerous. Don't try changing rear tires on the side of the road with these.
04-20-2017, 10:39 AM | #8 | |
Did the previous owner tell you the wheel width or did you check them yourself?
An '8 inch' wheel will have an actual overall width of approx 9 inches. In the photo I'm seeing spacer blocks between the springs and axle. They lower the car by raising the axle closer to the body. I'm surprised the rear tires will fit between the fender and brake drum enough to change them. Quote:
. Last edited by dmsfrr; 04-20-2017 at 01:53 PM. |
04-20-2017, 10:48 AM | #9 |
He told me they are 8" wheels. I questioned him about changing the tires and he said they went on using the lift. I didn't go into whether they deflated them or not because I was intending to change them to a smaller size anyway.
04-20-2017, 01:24 PM | #10 |
Since you were already considering the 215-75R15 tires, go with those on a 6 or maybe 6.5 inch wide wheel. The wheels you have are too wide for that size tire.
Without a good photo of the wheels & tires it's hard to tell but there might be a good chance you can sell them as a complete set, to help offset the cost of their replacement. If you really need to keep & re-use the wheels a good tire shop should be able to help you find something a bit narrower that isn't stretched out too far to fit the wheel. Do you want wide white wall tires? They aren't very available unless your wallet is fat. Keep your eyes open around swap meets and flea markets, parts store bulletin boards, even craigslist. Someone selling their stock wheels and tires after 'upgrading' their car, or looking to swap with you, might be just what you need. But don't get used tires over a couple years old. https://www.google.com/search?q=how+...utf-8&oe=utf-8 . Last edited by dmsfrr; 04-20-2017 at 01:57 PM. |
