04-11-2013, 08:11 AM | #1 |
Engine Head/Gasket
When removing engine head …
(1) any ‘tricks’ to this process in order to ‘save’ the gasket for reuse? (not an original, has been installed ~1 year) (2) would appreciate comments (pro/con) on use of the ‘modern’ (already with bead of silicon sealer) head gasket (in likely event I destroy the current gasket ) |
04-11-2013, 08:19 AM | #2 |
Re: Engine Head/Gasket
Why is the head being removed?
I've used copper coat on both sides and reused a head gasket with no problem, but it's always a risk and I wouldn't do it on someone else's engine unless they gave the OK. If you are changing heads there's more risk of a leak when reusing the gasket. |
04-11-2013, 09:13 AM | #3 |
I suspect you found the correct early head for you car? I agree with Tom on the
gasket... |
04-11-2013, 09:35 AM | #4 |
Please forgive me for possibly hijacking this thread. A few days ago, I read that the bolt holes should be counter sunk to prevent the metal from gushing out from under the nut and binding on the stud. How about it?
Terry |
04-11-2013, 09:37 AM | #5 |
i used the modern style gasket once and had nothing but external leaks never again only the copper for me.
i never reuse any gaskets |
04-11-2013, 09:56 AM | #6 | |
the head? 1. There should be a very SLIGHT champer...on the block. 2. I also like the same on the top of the head..because it has no washer. 3. Aluminum heads are a different story. |
04-11-2013, 10:01 AM | #7 |
1) I would never take a chance on reusing a head gasket ($39) . Lot of work doing this drill .
2) Modern head gaskets work ; You have to retorque with engine stone cold . And retorque more than the instructions say . Retorque until torque stays at 55lbs . Did mine 5 times . |
04-11-2013, 10:01 AM | #8 |
I reuse the gasket some times, but like Tom only on my cars. It is a risk, because Model A Head gasket seal is marginal any way.
04-11-2013, 03:09 PM | #9 |
Chief's probably "splittin' a gut" He didn't mince his words or rattle long explanations, I KNOW he would mutter, "Do you re-use a condom"?? In one QUICK hand motion he could explain the difference between FEMALE pipe threads & MALE pipe threads!
Anonymous W.
04-11-2013, 08:23 PM | #10 | |
04-11-2013, 10:38 PM | #11 |
My dad told me he did that during the depression years. He said he soaked the gasket in water overnight to swell the center material and it worked. I run a high compression head and wouldn't try it. How lucky do you feel? Gary
04-11-2013, 11:01 PM | #12 |
not a 'really' have to ... current gasket (copper/white) is from A&L but engine never started ... will be changing to a more correct E28 head so had hoped i could save the gasket ... i assumed the copper coat gasket sealer would hold the copper layers to each surface and shred the inner layer .. am on track of a NOS McCord gasket with the white asbestos liner so kind of a mute topic ... however, am always appreciative of sage advice!
