11-18-2023, 01:45 PM | #1 |
39 ford glovebox lock removal
I'm taking out the glovebox lock to get the code to have a key made. I pulled off the spring clip thinking I could remove the arm that locks the glovebox, no luck. I removed the screws holding it to the door. How do I get it out of the glovebox door?
11-19-2023, 08:11 AM | #2 |
Re: 39 ford glovebox lock removal
Pretty sure the lock cyl with the arm attached slides out the back once you remove the clip.
11-19-2023, 08:13 AM | #3 |
I was trying to rtake it out the front. Let me try that.
11-19-2023, 08:39 AM | #4 |
Once you have it out, let me know the code and I can cut you a key to code.
FlatHeadCoupe John McClure 919-559-5774 |
11-19-2023, 03:23 PM | #5 |
Ok folks, I finally got the cylinder out. There is a small roll pin through the little arm that locks the glovebox door. I pried it up but not out completely and it allowed the lock to come out of the glovebox door hole.
11-26-2023, 07:28 AM | #6 |
