11-27-2015, 12:38 AM | #1 |
Battery box and location
Can anyone supply a photo of the battery box and its location for a 1940 Ford Business Coupe?
I have a box but can not find where to put it on the firewall. Thanks, Randall |
11-27-2015, 04:27 AM | #2 |
Re: Battery box and location
See attached: https://www.google.co.nz/search?q=19...HQ0WCpYQsAQIGw
This should give you a location of the battery located on RH Side. Not much you cant find by just putting in a search. Best of luck. Phil NZ |
11-27-2015, 09:39 AM | #3 |
The very first photo shows what I think is the correct setup for a '40. The '40 tray is a one only part. C&G lists the tray as Part No:01A-10732,Hold Down Bracket as 01A-5171
and Hold Down Pad as 01A-5171 Others sell them also. |
11-27-2015, 10:07 AM | #4 |
Randall: As shown, the 40 battery box DOES NOT go on the firewall. It bolts
to the frame rail and is held in place by 2 nuts and bolts. Please don't make the mistake of cutting up your firewall as was done so often back in the days of early hot rods. Last edited by 19Fordy; 11-27-2015 at 10:30 AM. |
11-27-2015, 10:35 AM | #5 |
Doesn't get any more clear than this........NOTE 8v battery! DD
11-28-2015, 12:51 AM | #6 |
