08-02-2013, 12:18 AM | #1 |
57 Ford Draglink interchangable with 59
Can anybody confirm if the Drag link from a 57 Ford is interchangeable with the one on a 59 Ford. Also, are the Tie Rods interchangeable?
Thankyou. Mercman from Oz |
08-02-2013, 07:08 AM | #2 |
Re: 57 Ford Draglink interchangable with 59
I know the a-frames are interchangeable.I have 59 upper and lowers on my 57 ranchero so that I could use the 59 style link sway bar,and a 61 steering gear with rag joint and column.My guess would be that it would fit.60 and later won't fit because they have a wider track.
Milt/Las Vegas |
08-03-2013, 07:22 AM | #3 |
Yes, the stuff is the same. I raced a 57 on the dirt in the 70's, we bent up the steering racing up north, the donor car was a 59 and it bolted right on. Mark
08-03-2013, 11:09 PM | #4 |
When changing out drag link and tierod parts,remeber to center them,starting with the tierod when you set your tow in,do it so both sides are the same size/not adjusted all on one side or even mostly. After tow is site,you can then adjust draglink so steering wheel is in the right place when wheels are strait a head.
I'm looking for a old or froze up,4bbl 4100 carb,I can unfreez anything and rebuild my self,don't need chock parts. thanks for any leads. |
08-03-2013, 11:18 PM | #5 |
Are we talking about North American models or Aussie models? If you're referring to Aussie models, very likely no. The Aussie 57 Fords the same body style as our 55's & 56's. They were still produced until 1958 there.
In 59 they were finally the same body styles as in North America
1956 Ford Fairlane Town Sedan 292 V8 with Ford-o-Matic |
08-04-2013, 05:16 AM | #6 |
Regards Mercman <>< |
