06-27-2012, 02:48 PM | #1 |
Shift tower swap
The old guy with questions again.
Can I use a shift tower with the e-brake on the side on a transmission that had the e-brake in the front? Or do I have to have a transmission that is made for the e-brake on the passenger side?
06-27-2012, 02:51 PM | #2 |
Re: Shift tower swap
The transmissions are the are. The one that is different is the multi disk and it might work either way.
http://www.model-a-ford-4bangers.com/ |
06-27-2012, 02:53 PM | #3 |
I have a multi-disk in the coupe and the brake is in front if the trans.
1928 Model A Business Coupe Rebuild picture gallery here The light at the end of the tunnel has been turned off due to budget cuts. |
06-27-2012, 04:01 PM | #4 |
I had a July 1929 coupe that came with the tower with the early brake handle. I believe the change over was somewhere around mid 1929. I replaced it with a tower with the brake handle on the side as I wanted to add the quick release accessory. The tower was no problem, but I had to replace the rod that goes between the brake handle and the cross shaft. Bratton has them.
Tom Endy |
06-27-2012, 05:36 PM | #5 |
Thanks again for the help.
