12-10-2018, 07:10 PM | #1 |
Machine shop Sale.. 99 block+ parts
I have never assembled a Flathead V8, but hearing of a machined 99 block and parts at a 'going out of business' sale, I ended up with a fresh machined 99 block 3 3/16th plus .040, new pistons w/ rings[4], reconditioned rod set, all new bearings, fresh crank [.020/.020]. New valves, springs, and split guides. The block has 16 hard seats installed. No cam or lifters. Included was a Chev trans adapter. So during this Winter I will attempt to assemble this project. My experience is rebuilding Aircraft engines for 5 yrs and a few modern V8's. You all like photos so here is the start. First the stand fixture did not fit the block, the 7/16 holes were wrong as was an identical fixture, same mfgr, all fixed now. future reports to be posted for you all. Newc That Stude doesn't belong here!!
12-10-2018, 07:25 PM | #2 |
Re: Machine shop Sale.. 99 block+ parts
Nice score . Good luck and have fun
12-10-2018, 07:38 PM | #3 |
Lucky dog! And a 99 too! The adapter looks like it needs a later model (8BA type) clutch throwout lever. Hope that doesn't cause problems.
12-10-2018, 08:52 PM | #4 |
Cool
12-10-2018, 09:05 PM | #5 | |
12-11-2018, 08:08 AM | #6 |
12-11-2018, 08:20 AM | #7 | |
Will it mater? Not sure. If you want it to be dead nuts accurate, make sure you tell the cam grinder it's for a 99-series engine if that matters to you. |
12-11-2018, 06:10 PM | #8 |
I don't think it makes much difference, unless you plan on a Bovel record.
12-12-2018, 11:29 PM | #9 |
Good score!
