Has anyone ever heard of "Gorilla Hair"? It's sort of a super dooper body filler with lot's of fiber it. They recommend it as a base coat then you finish it with the Bondo. Half a can was given to to me to use with the story that they p[ut it on a jeep that they used for offroading and the stuff took it with out cracking. Just wondering.
Terry |
If you are fron the "Kill it and Fill it" school of autobody, don't let creaftmanship get in your way.
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical. |
Found mostly in excessive bondo abusive body work. JMHO.
It is used mostly on fiber glass bodies . It is also used when holes are in the part and you want to prevent moisture misture from the back side to penitrate your plastic. Most auto body materials only have a shelf life of one year before using it. I would through it out if you do not know how to read the code date on it.
Much better than bondo but it is basically finely chopped fibreglass strands in resin, so it has to be machine sanded, hence the top coat of bondo used to finish for paint. I use a type of gorilla hair that has stainless steel strands instead of 'glass in it. |
#7 | |
Yes, That's the impression I got from it. Here and there on my cowl patch panels, I got some distortions in the metal from welding that just seemed to need more than Bondo. I am not a big fan of polyester resins body fillers, but I can't do lead, so what else is there? Thanks for everyone's input, It's appreciated.
Terry Quote:
