04-30-2020, 03:54 PM | #1 |
Oil pump removal
I’ve been going over some things on a 31 roadster I just got. I dropped the oil pan to check for sludge - not too bad, a little on the bottom. It’s been a few years since I removed the pan on an A, but I remember the oil pump coming out with the pan. This one’s bolted on the side of the engine, I’m pretty sure this is incorrect. Should I reinstall the pan, remove the bolt and put in a plug? What are the ramifications of leaving it like this?
04-30-2020, 04:08 PM | #2 |
Re: Oil pump removal
Yes, i would remove the bolt and install a plug. Unfortunately if it really is a bolt they more than likely screwed up the threads in the block as they are/were ⅛" pipe thread.
04-30-2020, 04:08 PM | #3 |
Wonder if previous owner forgot to take the bolt out and reinstall the screw plug.
The screw plug https://www.brattons.com/plug-for-va...-manifold.html When you took off was pan, was/is there a large spring on the bottom of the pump? When you put the pan on, the spring holds the pump up into the motor. The spring https://www.brattons.com/oil-pump-retainer-spring.html |
04-30-2020, 04:18 PM | #4 | |
