Can't get Rear Drum OFF...???..!!!! ARGH-H-H.... When I connected my Emergency Brake (finally) and took my Coupe for a 60 mile drive, I noticed that when I pulled back into my shop and pushed the clutch in, she came to a stop without rolling like it used to. So I removed the clevis pins on the emergency brake rods and the tried to remove the rear drum. (the one that seems to be tied up). NO WAY. I tried a puller, still no luck. I tapped the hub with the puller tightened up. Nothing seems to work. Tried 3 days now. I had backed the adjuster up quiet a bit.
Any ideas ?? |
Re: Can't get Rear Drum OFF...???..!!!! Are you having trouble getting the drum to come off of the axle or is it off of the axle and loose and you still can't get it off of the rear end? Any chance you have hydraulic brakes and there are safety hubs installed (look for two studs and nuts and two bolts attaching the rear backing plate to the axle). What type of puller are you using (KR Wilson I hope)?
Charlie Stephens |
Re: Can't get Rear Drum OFF...???..!!!! Quote:
Did you mean axle nut instead of lug nuts? If not, you may have a new approach that I have never heard of before. Charlie |
Re: Can't get Rear Drum OFF...???..!!!! Did you use a model a hub puller or a standard puller? Try with both service and e brake clevis' disconnected to turn the drum with a pry bar if it turns it should come off. Here's two tricks ive learned if they're stubborn. Thread the axle nut onto the hub until it is flush with the end then torque on the model a hub puller as tight as you can. Then hut the end of the pulled spindle with a sledge hammer. If that doesn't work use a torch and heat in a straight line from the axle nut side in and if that doesn't pop it hit it with the hammer again. With the right tools and technique it will always come off.
I think it's the center axle nut that should be loosened... a drive around the block on loose lug-nuts can't be good for the wheels or the lugs... I have used this trick on the Model A and other vehicles with tapered rear axles, and it works. SC Frank |
Re: Can't get Rear Drum OFF...???..!!!! O.K., I have standard Mechanical Brakes, which had been replaced by the person who was remodeling it before me. I am using a standard 3-prong puller and I'm supprised I haven't busted it with the torque I've applied.
I've put torque on it til' I can't do it anymore, then used some penetrating oil, then tried tapping it with a hammer, even tapped the end of the puller screw, let it sit overnight, started all over in the morning. Three days in a row. I think I stopped just shy of busting the puller. I also used the knock-off puller from snyder's. I think I'll try the "driving with a 'loose nut' method first (actually my wife says I have been doing that forever, LOL) If that doesn't work, I will order the Snyder Hub Puller. Appreciate your help as usual.................Whew, sure is hot at 100+........... Always said I like SNOW better..... |
Re: Can't get Rear Drum OFF...???..!!!! Mitchell has a dandy hub puller, works on both types of hubs. Price is reasonable and shipping is only $5. Got mine in about 3 days after placing the order.
Re: Can't get Rear Drum OFF...???..!!!! Have you tried leaving it overnight with the hub puller in position and wound tight? Particularlt handy if nights drop to sub zero!
Charlie Stephens |
Re: Can't get Rear Drum OFF...???..!!!! I've had good luck with the plain axle knocker nut. With a wheel & tire on the drum & on the floor, jack up opposite wheel. With knocker TIGHT, rap it once with a large hammer, tighten knocker, rap it once, tighten knocker, etc. Keeping knocker TIGHT between blows will protect threads from possible damage. I tighten it with a large Crescent wrench and a blow from the LARGE hammer. Bill W.
Re: Can't get Rear Drum OFF...???..!!!! Use a 2-prong puller, tightened. Jack up wheel and then lower onto a piece of 3/8 thick steel placed in the hub groove that is given a very solid support from the floor. Take another 3/8 thick steel held in the top side of the hub groove using vise-grips to hand-hold this piece in place. Then bank on the top 3/8 piece with a heavy sledge hammer. If hub does not come off, rotate 2-prong puller 90 degrees and repeat with support and sledge hammer. If still no success, try a little heat and repeat with the sledge hammer.
This puts pressure on the axle taper similar to method for loosening tie rod ends on modern cars. |
Re: Can't get Rear Drum OFF...???..!!!! bobpo .....................
You didn't, sub-conciously, set the emergency brake, when you parked, did you ? MIKE :) |
Re: Can't get Rear Drum OFF...???..!!!! Make sure you back the adjuster all the way out, If new shoes were installed and the drums not turned, but worn, there will be a lip you need to get the shoes past, can be a big job.
This and the post that followed it make it a good time to ask. Is it correct to assume that the hub if firmly attached to the axle? The alternative would be that the drum is free from the axle taper and hanging up on something else. Charlie Stephens |
Re: Can't get Rear Drum OFF...???..!!!! I was thinking like the above posts, make sure the emergency break is not engaged and there is no tension on the service breaks.
I pulled my rear hub off last night to check break pad wear. I had to turn the adjuster wedge down quite a bit before the hub would let go. |
I know the drums were ground when the brakes were installed by the previous owner, I've got the receipt. And I only have about 1,000 miles on the car. Easy miles at that. ????????? :( |
Re: Can't get Rear Drum OFF...???..!!!! bobpo When you have the puller tight,dont just tap it to get the hub off.You have to use a 4# hammer & really hit it hard.I have never had a problem using a K O puller. make sure the K O is bottomed on end of shaft with a bit of space to hub.After every hit you have to tighten it to prevent damage to threads.Ive removed many hubs over the years & never had a problem.Also,raise the opposite wheel clear of the ground may help.
Re: Can't get Rear Drum OFF...???..!!!! Hi Bobpo
Make sure you leave a nut on the axle the nut flush with the end of the axle. You don't want to swell the end of the axle or worse crack it down the middle. Don't use your good axle nut. Find another and turn it upside down. So the castle is towards the hub but not against it. With your puller on the hub tightened hard. Smack it hard as columbiA says. PS. Hit the puller with your hammer straight on |
Re: Can't get Rear Drum OFF...???..!!!! Hi Bobpo,
I would never use a three or two arm puller on a Model A. I purchased the rear hub puler that Brattons sells for $29.50. Be sure to get the one designed for your style hub. Mine works great. Also be sure to put the axle nut on in reverse as described in reply 20 above to protect the shaft end. Good luck. Supergnat |
