What is the Best Method to Remove Water Spots I have water spots on the hood of my car that have been quite resistant to my attempts to remove them. I would appreciate any suggestions for products or methods that you have used to successfully get rid of water spots on your car's finish.
Thanks in advance. |
Re: What is the Best Method to Remove Water Spots If you haven't waxed the car yet, a simple solution of vinegar and water will got them off. You might have to use straight vinegar if they have hardened. If you have waxed the car........too bad.
Re: What is the Best Method to Remove Water Spots i use windex ............. steve
Re: What is the Best Method to Remove Water Spots Automotive clay is another good option.
