Car Is Shrinking........ ......or I'm getting too big for my '28 Sport Coupe! I bought this car 3 years ago and I was able to drive it, but somehow over the winter, I no longer fit. I have put on some weight I know. The problem seems to be when I have the car in low gear there is not enough room to move my foot off the accelerator and to the brake. Same boots as last year. I don't get it. Anyone else have trouble fitting operating the pedals? I think driving my '26 T is definitely out of the question! I haven't driven either one since last June and now it sort of scares me to drive them now. Just doesn't seem safe.....
Re: Car Is Shrinking........ Some people have modified their cars to add a few inches to the driver's compartment. I think there is a way to move the seat back but I saw at least one car where the body was modified. An expensive and time consuming project, no doubt.
I have a super 8 movie of my grandpa getting in my 30 coupe that I drove in high school. It was a struggle for him. I am now at his age when the movie was taken and it is little struggle to get in and out of my Model A. For me it helps to keep some weight off by exercise and reducing the caloric intake. One idea is to sell your Model A and T and buy a larger car. Maybe a Lincoln. |
Re: Car Is Shrinking........ I have seen a factory Service Bulletin about moving or modifying the seat somewhat for one model or another. The big problem I think I am facing is that the gearshift is just too close.
Re: Car Is Shrinking........ Our 1929 Sport Coupe we owned for 42 years. Reluctantly sold it two years ago for the reasons you have mentioned.
I really loved that car but I no longer was able to easily get in or out. Plus I was very much concerned about working the pedals and safely driving in todays traffic. I had gotten to the point were I was just enjoying the car while setting in the garage having a cold summer drink. A number of my friends have also decided to sell their cars. Age and health problems. Enjoy your car and life while you can. |
Re: Car Is Shrinking........ Quote:
https://live.staticflickr.com/65535/...3a27a304_z.jpg |
Re: Car Is Shrinking........ I did the same thing, my shifter was clocked at about 7 O'clock when I got my Roadster. I bent it to 6 O'clock and now it's perfect.
I did it with the shifter still attached and in the car. |
Did you have to heat it up or just start tweaking on it? |
Re: Car Is Shrinking........ Here is how I did it. I'm not saying it was the best way. But it worked well and did no damage.
I put it in 1st gear, sat in the car, and planned out how far I wanted to twist it to the right. Next I removed the shift knob and wrapped shop rags tightly around the shifter and bound them with masking tape to protect the shifter. Next I removed the handle from my floor jack (long steel tube) and slid it over the shifter. Then I took my left hand and placed it at the bottom of the shifter to hold the tube where the bend in the shifter is. I took my right hand and placed it at the top of the tube and started to lightly push in the direction I wanted it to bend. It did not require a great deal of force. I would only slightly bend it, remove the tube, and test the position. I did that until I got it where it was comfortable. |
Re: Car Is Shrinking........ I think that's my only issue. Sure, I'm 6' and 280, but I can drive the car even though it's cramped, but for some reason suddenly I can't feel safe with the shifter being this close & I can't move my right foot. Is there any danger of hurting anything in the transmission?
Re: Car Is Shrinking........ Try removing some padding from the front seat. That will lower the height enough to make it easier to get in an out. Older LeBaron Bonney interior kits ended up being too high in this area if you used all the padding they included in the kit. Although more work, you could also pull some padding out of the backrest, which will increase room even more and make entry and exit moves easier.
Marshall |
Place the shifter thru the eye bolts and slide down so the lower eye bolt is just above the bend in the shifter. Wrap some tape around the eye bolts so you don't mar the shifter. Tighten the large nut in the middle. https://live.staticflickr.com/65535/...a09fce3c_z.jpg I use the tool because I was concerned of putting too much stress on the internals by just bending it. But others have just bent it without issues. |
Seat can be moved 1 inch and 5/8ths towards front or rear from "Standard" position. I moved SEAT BACK to the rear on both upper and lower. Later I made a bracket to move lower seat-back even further to the rear. CAUTION: If you have Mitchell transmission, DO NOT try to bend shifter stick without heating it. These shifters are made in two pieces and only spot welded together. The other version are two pieces and threaded together. I am not picking on Mitchell I have seen both versions of shift levers made as REPRO levers in recent years. Mine broke in half just below the "Chrome Dome" while driving. The weld only penatrated about .060 to .070. Luckily it broke in second gear and close to the garage. |
Re: Car Is Shrinking........ Someone would make a fortune if they made a Model A steering wheel that was 3" smaller in diameter.
Re: Car Is Shrinking........ One of the guys that was formerly in our local club took 1 1/2 to 2" out of his clutch and brake pedals, then welded them back together.
Re: Car Is Shrinking........ why not wear sneakers instead of boots?
Have you seen the “Fat Man’s Steering Wheel” for a Model T Ford? Enjoy. |
